With the typical clunk tank (i.e., not Hayes), you can fiddle with the position of the internal end of the uniflow tube to adjust the engine run for insides/outsides rpm. This feature discourages one from fiddling with the tank, once set.
Also, the installation depends on tank cross sectional shape, round, square, or rectangular.
There are a few advantages and disadvantages to a typical R/C clunk tank. Advantages are that they're cheap and easy enough to carry a spare, if you're inclined, and they will allow you to do short flights, to check needle setting or to check wings level, etc. The main disadvantage (I'm using one) is that you can't do a "cutoff loop" to position your engine shutdown for best landings on a windy day.
I recently started running pipe pressure on mine, to avoid rich running into the wind and lean running downwind. Seems to have fixed that, although the alternative is to just hook a hose to the uniflow vent that ends somewhere inside the cowl, inside the backplate cavity, etc., where there is a constant pressure. I'll probably try that next.
