  • July 15, 2025, 11:17:06 AM
Author Topic: Fuel Tank Cleaning  (Read 1824 times)
Online Peter in Fairfax, VA
Fuel Tank Cleaning
« on: March 14, 2020, 08:22:22 PM »
So, my newly acquired but older Brodak .40 / Vector .40 combo is giving a problem.
At first, its started and ran fine.  However, after a couple of runs, it had trouble drawing fuel.  Metal uniflow tank, typical for Brodak Vector ARF.  Older tank with unknown history.  Small grey plastic filter; unknown filter maker.
Symptoms:
1.  Fuel was green when installed in tank.  When removed, fuel had changed color significantly to yellow.
2.  At one point, would not draw at all at the engine, using a syringe to draw.  Plugged.  Reverse flushed, then it drew, at least briefly.
3. Final tank end of day emptying found significant black debris drawn from tank.
4. Flew fine, then stopped at random.
Questions:
1. Is there a way to clean a tank while installed in a  plane?
2.  What's a good way to deal with this?
Comment:
This is an example of why profile planes are easy to maintain.
thanks,
Peter
Re: Fuel Tank Cleaning
« Reply #1 on: March 14, 2020, 09:22:01 PM »
  Hi Peter;
  The tank is built into the fuselage and not removable? This is the main reason NOT to build in your tank on a full fuse model.  Fill the tank with some acetone and let stand for a while and lug up all the tubes. If you can find a way to rig a separate tank to the engine, do so in that you can run the engine on the ground for at l;east two or three minutes at a time. You are doing this to use the engine to create a sort of ultrasonic cleaner effect on the tank. Run it once or twice, then let it sit. run it a few times more, then flush the tank with clean acetone. If it comes out clear, do a test run one the ground, again, in short runs, like you are breaking in the engine. When the tank is empty, check the fuel filter and see what you caught. If there is anything in there, repeat the ground run process. Not as time consuming as it sounds, and it will shake loose anything in the tank that can be shook loose. I like to use white vinegar also, as it will attack rust also and has cleaning abilities on any sludge, and the engine vibration really is the secret.
« Reply #2 on: March 14, 2020, 09:28:23 PM »
Questions:
Comment:
   Comment: Don't build tanks into airplanes so they can't be removed!
   The best way to deal with this is to remove the tank, throw it away, and make a new one. A possible way is to fill it with Evapao-rust, leave it for a few days, suck it back out, repeat. Then flush with alcohol to remove the water, then lacquer thinner to remove the water. Shake the airplane, if you hear anything rattling around, cut the tank out, throw it away, and make a new one.
« Reply #3 on: March 15, 2020, 04:15:14 AM »
Since I have two more identical tanks, access via a hatch and silicone seal to hold it in, should not be difficult to do an R&R (remove and replace.)
I'm starting to think that tanks should routinely be cleaned BEFORE storage.  Some alcohol stove fuel may be the ticket.  Or vinegar or acetone.
Peter
Online Lauri Malila
« Reply #4 on: March 15, 2020, 04:35:30 AM »
I have made dozens of tanks, and never had issues with rust/corrosion. Those few I have opened after long use just for curiosity, were perfectly clean inside.
So, what can cause your problem?
-Only use copper tubes for plumbing.
-Only use tinned steel (?) for making the tank. No Brass sheet!
-Don't use a scriber for markings when making the tank. Instead use a thin pen. Also, don't bend the metal against metal, but rather hardwood. Or at least protect the bending tool with cellotape.
-With good soldering iron and everything well cleaned, a usual rosin core solder (for electronics) is enough, no need for anything more aggressive.
-When ready, flush with laquer thinner.
Lauri
« Reply #5 on: March 15, 2020, 09:21:09 AM »
Peter
     Well, if you have a replacement tank, then there is the answer, and you can remove the back from the problem tank and clean it out. Just don't get too aggressive with tools and such as Lauri mentions to cut through the tin coating. If you get it clean enough to be reliable, then re-solder it using the rosin core solder mentioned and a minimum of flux applied to the outside of the tank only, test and flush well. Then when not flying it,just store it with some kind of fluid like stove fuel and make sure it is completely full, then cap it off. I used to use fuel, until these nitro situation arose and the quality of nitro in anyone's fuel is at question. Everything that Lauri mentions about building a tank is spot on, especially the brass tubing. Put a short scrap of brass tubing in some fuel in a baby food jar and let it sit, and watch what happens. Years ago at the hobby shop I worked part time at, we sold K&B fuel, and then Red Max hit the market at a cheaper price. They were the first to use imported nitro I think, and we had all sorts of guys complaining about how much trouble they were having with engines,tanks and such. More often than not,  we found that they were using Red Max fuel. We kept a display of brass tubing/fuel in baby food jars like I described so customers could see the difference. That was when there was nitro production in this country, and these days it is all imported and has an acid effect on anything ferrous like bearings, cranks and the steel under the tin coating on tanks and can attack brass over time.
    I come from a back ground where there wasn't a lot of money to go around and I had to make do with what I had and repair things where ever possible. Old habits are hard to break and I still spend time fixing something that I really should just throw away. Sometimes, fixing what you got can be the only option. I came up with the cockeyed method of cleaning the tank out of necessity in recent history. I came into possession of a Fierce Arrow stunt model that was built by and belonged to Mike Gretz.  I considered Mike to be a good friend and the airplane is pretty special to me. It is finished in silk and SIG dope as you might expect and powered with a Fox .35. When examining the nose of the airplane, there was only an over flow tube sticking out. I figured Mike just filled it through the feed line. I do not own ANY hanger queens in my house, and fully intended to fly this airplane every once in a while just in Mike's memory. I flew it carefully a few times to feel it out and check run times and such, but ran into issues like Peter described, and found rust flakes in the fuel filter. Mike built the tank into the nose of the fuselage, and no way to access it, and I sure as hell wasn't going to cut into the fuselage to try and figure a way to get it out. While sitting there staring at the nose, it hit me that the engine vibration is a pretty fine frequency, and that's what was breaking the rust loose. Desperate times call for desperate measures, and that is when I came up with the method I describe in my first post. It has worked like a charm, and I just store the model with the tank filled like I described. Stove fuel is pretty cheap at Wal-Mart and will protect the inside of the tank. When I flush out the tank to fly the airplane, I put one ground run on it so that first tank of fuel will flush out anything that was left in the tank, check the fuel filter, and then fly with some confidence things will be OK and remember the fun times I had hanging out with Mike Gretz at the SIG contest.  Sometimes, you just can't do what is the most obvious thing to do to correct a problem, and you HAVE to use what you have in front of you. I have had other old models I got from various places with built in tanks and since the airplanes had more problems than they were worth, I stripped off what I could use like engines, vintage wheels and hardware, and then give the air frame away or give it a Viking funeral. But this Fierce Arrow was not in this category, and I thought Peter's model might be like Fierce Arrow. It's like the old saying says, sometimes a man has got to do what a man has got to do!
  HAPPY ST. PATRICK"S DAY TO ALL!
« Reply #6 on: March 15, 2020, 11:27:23 AM »
   Exactly, this is how I make mine, too. The problem that I have seen with "factory" tanks, again and again in the last 10-15 years, is extreme rust. I think this is because the manufacturer uses some sort of acid-based flux. The rust is almost always around the front and rear end caps, never in the middle of the tank. I think they crimp and solder the body, then dip the ends in either acid flux or solder paste, then stick on the end caps and solder it.
    I have seen many people with a bad tank go find another one, still in package, and when you shake it, you can hear the pile of rust sliding around inside - so that one is just as bad. Those I make myself never rust, my material is nominally the same thing as they use (although probably a higher grade) so I figure that fuel and storage is not the issue.
   This is also why I think Evapo-rust will at least have a short-term effect on it. If the only issue is rust, this will make short work of it. That's not nearly as good as replacing the tank. I think once it is significantly rusted, you probably can't make it last, long-term. I do know that some tanks made with StaBrite by individuals can get to the point that the rust has eaten so much material away that it can cause a bunch of pinholes that can essentially never be repaired.
« Reply #7 on: March 15, 2020, 12:15:42 PM »
I did replace the tank with another one, subject to leak testing with air and final silicone adhesive.
Huge quantities of junk continue to come out of the old tank, even after several acetone flush attempts.  And, on top of that, I realize that I knocked a hole into the old tank with a cowl attachment screw.
The new tank, which is also larger, passed the acetone flush test.  Also, the new tank is set further back from the nose, so the attachment screws miss it.
Not sure how I would implement a "store it full of stove fuel" procedure, as attaching the feed line to the engine can be difficult with a box fuse.  For a profile, easy enough.  I do agree that fuel tank construction closely resembles the quart fuel cans from the hobby shop, that storing full is not a bad idea.
Thanks for all the advice,
Peter
« Reply #8 on: March 15, 2020, 12:31:28 PM »
  If it makes you feel better, yes, but it is patently unnecessary if the tank is constructed properly with the proper materials. Pop the back off the old  tank, I bet you find that it has a ring of rust inside both end caps, and around the tank body fore and aft. This is from improper soldering materials and techniques, and maybe due to lower-quality materials (thinner plating).
  If am not sure why it is any more difficult to leave it full of fuel on a full-fuse airplane as opposed to a profile, in both cases, you fill the tank completely, then plug all the tubes. Then you can store it however you want.
  BTW, since you can now get to the new tank, *check it before you install it*, because it could easily have the same problem. At the very least, pop the back off of it and see if there is a rust ring, and if the tubes are properly located and *soldered to the side of the tank at both ends*.
p.s. looking at your tank, you can see the extreme rust on the outside, that is where the acid flux got on it, because it will not rust that way otherwise.
