  • July 17, 2025, 04:26:34 AM
Author Topic: Fuel mix how is weight vs volume different  (Read 6022 times)
« on: December 05, 2018, 02:47:34 PM »
 " Randy would you be good enough to explain the difference between weight and volume, and which is the better?
  Thanks a lot.. "
Fuel has normally 3 ingredients, Methanol   Nitro and  oil. When you mix fuel by liquid volume, the parts are all measured by fluid ounces,  When you mix fuel by weight, you are able to save money because the expensive parts, nitro and oil, are heavier than methanol , which is the cheapest ingredient. So you are using LESS of the two expensive parts, and more of the much less expensive  methanol .
The specific gravity of nitromethane is way higher than methanol and oil is higher also.
Bottom line example of this is a gallon of whaat the fuel company says is 10% nitro is more like  7% , and  the oil they say is 18%, when a boil down test is done,, it is much closer to 14.7 % oil by volume.
This is not a huge problem, as long as you know how it is mixed, knowing that you can adjust as needed, and buy the product that most fits your needs.
PS  at leaast 1 of the fuel MFG product that was to be 18% oil , was actually 12.5%  , however most  were  14 to 15% oil
« Last Edit: December 05, 2018, 04:35:37 PM by RandySmith »
Re: Fuel mix how is weight vs volume different
« Reply #1 on: December 05, 2018, 03:18:30 PM »
I see that Randy has started a new thread to pull out the fuel mix issue from the FP 40 Mods thread. So at the risk of offending someone by dropping my prior post into this one.... Randy has obviously provided the answer. But perhaps my example will help illustrate what we are both saying.
This came up (again) when Gil asked for a tutorial on why measuring by weight was different than measuring by volume. Here was my answer from the other thread.
Here is the refresher course--
The density of the three ingredients are all different. If they were the same, then there would be no difference between a percent by volume mix and a percent by weight mix.
The densities are as follows:  Nitromethane 1.14 gm/cc;  Castor 0.961 gm/cc; methanol  0.79 gm/cc
For reference, the density of water at 25C is 1.00 gm/cc
We assume that the ingredients are not miscible, thereby screwing up volume-after-mix observations or calculations. (edit--I meant to say that the three constituents, when combined, do not sum to a lesser [or greater] volume than the original parts.  I can't remember the correct term for that. Chemistry was a long time ago....)
Example
For a 10N, 22C, 68Al fuel mix by volume, the mix by weight would be 13.22N, 24.51C, 62.28Al. So if you are accustomed to thinking in volume measurements what has been working well for you, you can see that you would have to specify a higher oil content percentage if it were communicated on the basis of weight. Else, you would be a few percent short.
Conversely, if you used your "normal" percentages (volume) but your fuel mixer assumes you meant by weight, because that may be how he does it, then...
A 10N, 22C, 68Al fuel mix by weight, results in a 7.45N, 19.44C, 73.11Al mix by volume
Your engine would not run exactly the same. As you run a lower and lower oil and nitro percentage, this unintended "reduction" might be critical and cause damage.
Note that the alcohol constituent is by far the least expensive of the three. A cynic might say that a fuel mixer would make his product based on weight, but be vague about the basis, because it lets him put a percent for nitro and oil on the bottle that make you feel good, but reduces his costs significantly.
Note that it does not matter how the manufacturer is blending; in other words whether he uses a flowmeter or a scale or a whatever (as long as it is accurate) but we need to know the basis for the percentage given. I think all of us using the fuel assume that the percentage is by volume. But if the peerson blending does not follow this convention, and it isn't stated on the bottle, then we are not going to be happy with the results.
I thought that I could get to the bottom of this by looking up the Manufacturer's Safety Data Sheets (MSDS) which are required for chemical products. Unfortunately, the ones I have looked up did not give the basis of the percentage which surprised me, and further that most are also written giving a huge range in percentage of the ingredients. So they are not useful for our purpose here.
That leaves you with the same evaporative measurement testing that has been described in other posts. Unless you are doing large samples, or have very accurate measuring capabilities, you probably are not learning the true composition of your fuel.
Hope this helps,
« Last Edit: December 05, 2018, 06:33:50 PM by Dave Hull »
« Reply #2 on: December 05, 2018, 03:32:05 PM »
Randy (or Brett, if you've got your ears on) -- could you describe how to do the boil down test properly?  I've got some fuel that I may or may not have doctored up with extra castor, and I want to make sure.  (It was written on the side of the bottle.  In felt pen...)
Can I weigh a test tube, put in some fuel, weigh, then boil it with a heat gun until it don't boil no more, then weigh, then do some math?  If I'm at the point where it won't boil any more from a typical Monocoat gun, will that have boiled off the nitro?  Should I use my propane torch instead, or oxy-acetylene?   ~^
Brett's described this using measuring cups, but I'm a cheap skate and would like to do this with five or ten grams of fuel (my scale is good to 1/10th of a gram).
« Reply #3 on: December 05, 2018, 04:30:32 PM »
Example
Your engine would not run exactly the same. As you run a lower and lower oil percentage, this unintended "reduction" might be critical and cause damage.
Hope this helps,
Hi Dave
Excellent post, thank you,  I did not  pull it from the 40 post, I had a member send to me, a PM asking this question, I chose to answer it in the  engine column , Glad you posted yours here too.
and  Tim  This is how I do the test, I have a 100ml  glass Pyrex container, I put in 100ml of the  fuel, then I take it outside, OUTSIDE .. and put it in a pot, that sets on a hot plate, I boil the water in the pot, then put in the  100ml beaker, stir as it boils untill all that will  boil out is  gone, then see what is left, 15ml would be 15% oil  20 ml left  would be  20% oil
I assume if you have a tremendously accurate  scale that measures parts of a gram, would maybe be able to tell you what amount of oil is in your fuel, You would need to know  exactly what the Nitro percent is, and you need to know the  specific gravity weight of the oil in your batch, then do the  math of the other components, you should be able to get an answer
However I think the boil down test  would be much easier, and  you do not  have to use a  full 100ml
PS  TIM  do not  use  a torch, open flame...not good..  Use the  heat gun It will  boil off  all  the nitro and methanol
« Reply #4 on: December 05, 2018, 04:55:31 PM »
The part about the open flame was a joke.  Really.  Honest.
And I was thinking I could do it by weight, but was forgetting that pesky bit about the nitro being denser.  I suppose it's better to be half a cup shy of fuel and actually know what you're running through your engine than to be running Mystery Fuel.
« Reply #5 on: December 05, 2018, 06:28:21 PM »
The method you use has to acknowledge the things that you don't know, or don't know accurately, or the limits of your ability to measure. An evaporation test has advantages since it is a differential measurement, potentially reducing errors. That said, the issue of accurate knowledge of the ingredients and their specific gravity is troublesome, especially as regards the types of oils. Fuel that has absorbed some water, or was made with "less than anhydrous" alcohol will over-report the oil content as well. I don't think this would be significant.
I took a look at simply using a specific gravity kind of test just to see how sensitive that would be. It turns out that the difference in weight of one gallon of 10N-22C-68AL vs. 10N-28C-62AL is about 35 grams. For a pint sample, it would only be 4.9 grams. (A pint is 473 cc, or nearly a full 500ml graduate).  This works out to about 1.2%, so you would need to be working with accuracies of less than 1% for this to be meaningful. Not sure how accurately one can read the meniscus on a fat graduate like the 500. Also need to verify that your gram scale has the accuracy claimed over a large range, since this type of measuring is at both ends--as much as most scales can take, and as little as it will measure.
« Reply #6 on: December 05, 2018, 06:31:17 PM »
Dave, for my purposes I just need to know if I'm working with fuel that's 20%, 25%, or 29% oil.  If I'm in that ballpark, I'm good.
« Reply #7 on: December 05, 2018, 06:36:46 PM »
Tim,
What is your oil type and mix?
« Reply #8 on: December 05, 2018, 07:30:36 PM »
Tim,
I've got some all-castor jugs, and a couple of jugs that are all synthetic RC fuel + castor.
« Reply #9 on: December 05, 2018, 08:27:09 PM »
Hi Tim   use the  boil down method  and  stir  the  fuel  to help get all the  water and  alcohol out
PS  I knew you were  teasing, that was  why my PS  :=)
« Reply #10 on: December 05, 2018, 08:43:15 PM »
    You can do it that way, outside, presumably. But as Randy notes, it doesn't work nearly as well as boiling it - you never seem to be able to burn it all off without also boiling it to get the volatile compound vaporized. But once you do that, it just evaporates without burning it. Everytime I did a burn-off, I got a higher oil content than with boiling, probably because it never got rid of all the nitro and methanol.
« Reply #11 on: December 05, 2018, 10:31:41 PM »
Tim,
With careful measurement, you should be able to tell the 20% all-castor from the 25% using just a 4 oz. sample. The delta is about 5.7 grams. If the accuracy of your scale is <0.5% of full scale (based on a 500 gm capacity) then the error would be less than 2.5 gm. It is near zero endpoint, so nulling the scale should improve that. The rest of the error can be allocated to the volume measurement. You need something a lot better than a 5 fl oz "horse syringe" because you are trying to differentiate between 0.8 fl oz of oil and 1.0 fl oz, or 0.2 fl oz. So you have to be able to measure the initial sample, say, 10 times more accurately than that. In other words, down to 0.02 fl oz or 0.6 ml. Of course, we don't really know how complete the evaporation process is, which is another error source.
10N-20C-70AL --->  22.74 gm castor (23.66 ml) in a 4 fl oz sample
10N-25C-65AL --->  28.42 gm castor  (29.57 ml) in a 4 fl oz sample
Will be curious to see how your test turns out.
« Reply #12 on: December 06, 2018, 11:48:17 AM »
Mr. Motor,
What are you using to label your plastic jugs?  I have been cleaning with alcohol, then using a wide Sharpie pen, followed by taping over it with clear packing tape. It seemed to work until recently, when I lost track of the Fox fuel and some other because the ink seemed to have washed away. My next thought is to wire tag a card to the jug handle. But if you have a better system....
Divot
PS--I found out my mistakenly switched fuel jugs when my Fancy Pants won the unofficial Fox Sport Speed non-contest recently. It sure cleaned up the varnish, though....
« Reply #13 on: December 06, 2018, 02:13:47 PM »
Tim,
With careful measurement, you should be able to tell the 20% all-castor from the 25% using just a 4 oz. sample. The delta is about 5.7 grams. If the accuracy of your scale is <0.5% of full scale (based on a 500 gm capacity)...
It's a 5-ounce scale (so, 150gm) that I got when I was building indoor freeflight stuff.  Or dealing meth.  Dang, I can't remember.  It involved white powder and funny smells and money flowing away from me.  Oh wait -- money flowing away -- musta been modeling, then.
« Reply #14 on: December 06, 2018, 05:45:32 PM »
Mr. Motor,
Divot
I have better  luck writing on the  cap with a thin sharpie
« Reply #15 on: December 26, 2018, 09:50:24 PM »
I use a little round cardboard tag with a metal lip, tied to the jug, and write on the tag with a ballpoint. Use the same thing for straight gasoline, and gas/oil mix for the various power tools around that burn hydocarbons. The ones that burn electrons only need their smoke refilled, but I send them to the factory to have that done...that is, if they want them back. I'm currently (pun intended) trying to get my electron-powered chainsaw replaced after they said they'd send a new one just after Thanksgiving. Maybe Tim knows how to refill the wires with smoke? What % smoke is advised? ??? Steve
Offline Fredvon4
  • Central Texas
« Reply #16 on: December 27, 2018, 10:20:59 AM »
Properly labeling everything in the shop and knowing it's right has it's advantages
This  ^^^^
I mostly blend INTO new clean metal cans ...pints, Quarts, 1/2 and 1 gallon
Permanent Sharpie is NOT permanent...so a skim of clear packing tape over the label on the can
Fred von Gortler IV
« Reply #17 on: December 27, 2018, 12:20:03 PM »
You are preaching to the choir about proper labeling, Freddo. Tim and I aren't arguing the point....
I hope you have better luck with the packing tape than I did.  It had worked for me for a long time--until it didn't.....
I suspect that the difference is that I started hanging my fueling syringe over the top of the jug to keep it off the top of the toolbox and off the pavement. That might have allowed some seepage under the packing tape. And, with the large changes in air temperature, the jug may be flexing and causing the tape to buckle. That shouldn't happen with a metal can. I just got tired of rusty cans and the filter cleaning merry go round.....
I'll probably make up some metal tags that I can attach to the handle. Fix the problem once--permanently!
Divot
Offline Dave Moritz
« Reply #18 on: February 12, 2019, 09:08:55 PM »
Hello All:
Resurrecting an old thread here. I conducted Randy's suggested boil down test on a mystery fuel. Nice way to do it, and I feel reasonably confident with the results. Thanks, Randy.
My reason for posting is to add a couple of hints. First off, I found that the mixture is easily superheated when subjected to hot water. Thus the mixture in the beaker was prone to boil over unexpectedly into the water of the surrounding pan. I found this out the hard way when I placed the stirring stick into the already superheated fuel mixture and got a wild boil-over! So follow Randy's procedure exactly, and remember to put the stick into the mixture while the juice is still cold. Another point: the mixture needed constant stirring, and the process was kinda slow going (20 minutes to get the job done here at 900 feet above sea level). Finally, next time I'll use a beaker with excess capacity so that there is lots of room for hubbly bubbly above the mixture's surface.
Chow for now.
Dave Mo...
