  • June 20, 2025, 11:17:02 PM
Author Topic: Stockings as air filters  (Read 1607 times)
Offline Paul Allen
« on: September 03, 2011, 01:16:11 AM »
Guy's
       Stockings when used as an airfilter, do they have a reasonable lifespan?
Re: Stockings as air filters
« Reply #1 on: September 03, 2011, 06:45:45 AM »
They do for me. I run two to three layers on my Red Head McCoy's, as filters and also to restrict the intake for a better run. After a couple of years they get clogged up with dried castor, and I need to change them. Whenever my motor runs start to deteriorate I know it is that time.
« Reply #2 on: September 03, 2011, 04:54:34 PM »
I second Jim's observations.  It only seems that they get dirty/clogged after a while.  Nylon stockings will last a long time.
You can do a lot of experimenting with the number of layers which effectively works like changing the venturi size.
Big Bear
« Reply #3 on: September 03, 2011, 05:40:57 PM »
I have two issues with the panty hose filters. 1) They are so stretchy, I see no way to get anything like consistent results. The same mesh can vary radically from one install to the next. 2) I had one go wonky on my PA .51, and naturally thought it went down the venturi, because the engine was not free, but kinda lumpy. Turned out that the mesh got down around the drive collet and a little bit stuck into the front bearing. I cannot envision how that is possible. I think I was just belching :## the engine at the time. I haven't belched it since, largely because it doesn't seem to help me get it started any easier. The problem is not getting it wet enough, but I haven't gotten the process down yet.  n~ Steve
Offline phil myers
« Reply #4 on: September 05, 2011, 12:53:58 PM »
This may be a daft question(s), but how do you 'fix' the stocking on to the venturi, and how come the stuff doesn't melt??
Phil
« Reply #5 on: September 05, 2011, 01:04:46 PM »
Phil
Hi Phil,
You use an O ring to hold on the layers.  It doesn't get hot enough on the venturi to melt the material.
Big Bear
Offline phil myers
« Reply #6 on: September 05, 2011, 01:10:07 PM »
Thanks Bill
Phil
« Reply #7 on: September 05, 2011, 01:19:33 PM »
I think the more standard fastening of Nylon (panty-hose) is with Nylon "tie-wraps"  You can really crank them down tight!
« Reply #8 on: September 05, 2011, 02:10:58 PM »
Hi Floyd,
The ones I have seen (and mine) use O rings so that changes can be made easier than with tie wraps.
