  • June 26, 2025, 01:49:39 AM
Author Topic: Fuel issues  (Read 1285 times)
ChrisSarnowski
Fuel issues
« on: August 06, 2012, 05:47:33 AM »
This past week I started using the Morgan Omega 10/22 control line fuel.
The LA46 is set up with 1 extra head shim and a Thunder Tiger 11x4.5 prop. Also using the stock muffler since I could use the nose weight.
Well, my LA46 in the Kestrel was not happy with it. Basically power seems down with this fuel. I had tested at both sea level (home field) and also at the Lee, MA contest this weekend. Bill Hummel gave me some Powermaster GMA 10/22 and the engine returned to performing well.
Any comments? The Omega says it is mixed by volume. Did I get a bad jug of fuel? Throw in more castor? Seems ok in my Magnum 32 combat engines.
-Chris
Offline Bootlegger
Re: Fuel issues
« Reply #1 on: August 06, 2012, 06:05:46 AM »
  Chris, I am using the Omega C/L fuel in my 46 engines, and I add about 2 oz's of castor to the fuel, and they run fine with it.
  You might try adding some castor to a small amount of the fuel, and see what happens, that way you don't waste the castor...
 Good luck, and keep us posted...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Perry Rose
Re: Fuel issues
« Reply #2 on: August 06, 2012, 06:39:04 AM »
I have two LA .40's in louisiana that run very well on the Morgan fuel. I mix my own fuel for the rest of the pack here in CT. 3 gallons of methanol from a speed shop, one gallon of Fox castor oil and one gallon of Powermaster 10/22 or 15/23 what ever is at  Hog Heaven at the time. Works for me. I open the head with a ball end mill also. APC 12.25 x 3.75. APC 11x4 on the LA .40's Cold start launch at 9200. Should have tried 9500 at Lee yesterday.
Re: Fuel issues
« Reply #3 on: August 06, 2012, 08:41:57 AM »
Hi Chris
So  far, I have never had any Morgan fuel that is as strong as the fuel I mix, or SIG fuel, I mix mine by volume, and the Morgan is always down on power in comparision
ChrisSarnowski
Re: Fuel issues
« Reply #4 on: August 07, 2012, 05:40:21 AM »
Thanks for great info guys. I will try some extra castor tomorrow to see if that helps, otherwise I guess I'll run it in the speed limit combat planes.
-Chris
Offline Allan Perret
  • Proverbs
Re: Fuel issues
« Reply #5 on: August 07, 2012, 05:59:13 AM »
Hi Chris
Randy, have you tried the new Morgan control line blend, (10-11-11) it is mixed by volume.
I use it in PA65 and Stalker 51, seems to work good for me.
I have not made any back to back comparisons with SIG or any other fuel.
Others in the our club use it in LA-46, working good for them also.
Allan Perret
AMA 302406
Slidell, Louisiana
ChrisSarnowski
Re: Fuel issues
« Reply #6 on: August 08, 2012, 09:00:03 PM »
I took a quart of the Omega 10/22 control line fuel and added 2 oz of castor.
Well, the LA46 responded better and I was able to set the RPM's to a good range for the prop.
Flight performance started out good but then at the end of the pattern the engine ran away, going into a 2 stroke and staying there.
So I have decided that I should use the Powermaster GMA 10/22 in the LA46 instead of the Omega. That seems to work better for me.
As they say, your mileage may vary. Use what works for you.
-Chris
Re: Fuel issues
« Reply #7 on: August 09, 2012, 08:27:25 AM »
Hi Allan
Yes I tried the new fuel
