  • July 05, 2025, 06:40:28 PM
Author Topic: Fuel , GLO-plug and running tips  (Read 124156 times)
Offline Ghost123uk
  • ghost123uk
  • Control line flying in Chester, N.W. UK
    • Computer Support
Re: Fuel , GLO-plug and running tips
« Reply #50 on: August 12, 2019, 03:04:15 AM »
Hi all from the UK
I have read Randy's words at the top of this topic but was curious as to folks views on the following.
I am a keen user of the old OS Max motors. The earlier ones with the strap on muffler. I use a .40 in a stunter and I use a couple of .25's in "sport stunters".
My .40 is now suffering from lack of compression and one of my 25's is getting slack and has some big end wear.
I was very fortunate to source a very good nick .40 and a new "old stock" .25  8)
I want these to last, so I did some research. I have for a long time been using 20% Castor and 5% Nitro. I now realise that these old iron / steel motors should have around 25% oil for "our" use.
My question is this. If I were to buy a fuel that is 18% Klotz Super Techniplate oil (which has 20% Castor in it) and then add 7% more Castor, that would give me a total of 25% oil, of which 14.4% would be synthetic and 10.6% would be Castor. Would that be a good mix?
« Reply #51 on: August 12, 2019, 08:10:58 AM »
Hi all from the UK
HI
The answer to your question is  Yes, that mix will be a much better formula than the one  you have been using, the engine will get better protection, and will last longer
Offline Ghost123uk
  • ghost123uk
    • Computer Support
« Reply #52 on: August 12, 2019, 08:34:00 AM »
Thanks for the input Randy  8)
Just checking one thing , would it be OK to use the 14.4% Synth / 10.6% Castor on the used engines?
Hoping the Synth content won't clean off any "sealing" castor residue from the piston liner seal......
I will use the mix on the "new old stock" OS .25 Max I am about to run in though
« Reply #53 on: August 12, 2019, 12:45:38 PM »
That would depend on how  bad the  castor build up is,  Are the  sides of the  piston Dark Brown? or do you still see the metal?
Offline Ghost123uk
  • ghost123uk
    • Computer Support
« Reply #54 on: August 14, 2019, 02:10:58 AM »
I have 5 of these engines (old type OS MAX) and they show varying degrees of "coating" on the piston, from a "new old stock" one I am currently running in, to very well used ones (including one which is now in the "spares only" bin as it is clapped out and has a lot of big end play). Last Thursday I flew both all three models that I have that use the OS40MAX and the OS25MAX engines on 5% nitro / 20% castor, with added Castor (Southern model craft brand) to make it up to 25%. I used the same plug (OS 8 ). I found that the run and the nice 4-2-4 break was still fine, no issues arose. More muck on the wing however (as expected). I did not detect any variation in temperature on landing, but was only using the finger on the head method!!
In view of this I have decided to play it safe and keep it simple, by just adding castor to bring it up to the OS recommendation of 23% to 25%, I will use 25% as I am not after every last bit of power and wish the motors I have to last.
I did the maths and adding the extra 5% castor brings the Nitro content down to 4.8%, which I very much doubt makes any difference from the 5% original.
« Last Edit: August 14, 2019, 03:24:26 AM by Ghost123uk »
Offline John Skukalek
« Reply #55 on: December 31, 2019, 03:39:16 PM »
This is a question for Randy. Based on the very valuable information that you have provided throughout this thread, I have learned how to get the oil % in my fuel to levels that I have targeted. I buy Omega fuel at my local hobby shop. The mfg shows 17 % of combined synthetic and castor oil. Understanding that the 17% is based on weight, I convert the 17% to a volume % using 81% which results in 13.8 %(volume). I add castor oil to raise the combined oil % to 22% for my Brodak 25, Brodak 40, OS 40 FP, OS 25 LA. I add castor oil to raise the combined oil % to 28% for my Fox 35's, OS max 35(Art Adamisin reworked) and worn out Super Tiger 46s.
My primary question is with regard to the nitro %. What is the conversion % for it? It's not the same 81% is it? The omega fuel that I buy to start with is labeled 10% nitro.
Also, I have an old OS max 10 and OS max 15. Do they like the 28% oil and 10% nitro? More nitro?
Any thoughts/recommendations with respect to what I am doing as described above?
I am looking for the 2-4-2 break.(for the 35 - 46 motors)
Thanks for all of the information that you share.
I have sporadically dabbled in this stunt hobby for short periods over the last 30 years and want to get serious about it now that I have more time
« Reply #56 on: December 31, 2019, 06:52:55 PM »
hi John
The nitro is  the heaviest component, it weighs more than the oil or methanol. So the 10% nitro is slack, and  adding oil makes it lower, I would suggest if you need 10%  , then buy 15% Omega, and by the time you add oil, it will be  close to  real 10%. At least if you buy 1 gallon of the 15 and try it, you will know if that will work for you
Offline Colin McRae
  • Are we having fun yet??
« Reply #57 on: December 22, 2022, 05:39:09 PM »
Great article. I am getting back into CL after many years.
I thought I would share this fuel mix calculator spreadsheet in case anyone is interested.
It is based on 32 oz finished volume after the mix.
