  • June 19, 2025, 02:37:04 PM
Author Topic: OS 10FP venturi and prop  (Read 2555 times)
« on: September 08, 2016, 07:55:41 PM »
An OS 10FP has come into my possession.  It has a custom -- and seemingly severely undersized -- venturi, and at 8-4, a severely oversized prop.  The thing doesn't want to stay running; before I do anything else I want to get it set up correctly and see what it'll do.
What's the right size for the venturi on the 10FP?
Re: OS 10FP venturi and prop
« Reply #1 on: September 08, 2016, 09:00:19 PM »
I had a stock Cox .049 venturi (.118") on an LA 10 with 7-3 prop. If you have an OS spray bar across the hole the right size (5/32"?) would look tiny.
Offline Akihiro Danjo
« Reply #2 on: September 09, 2016, 01:45:57 AM »
Hi Tim san,
Please read this thread.
Stock venturi is 6.0mm and the stock NVA is (4.0mm stepped down) 3.5mm.
Aki
http://stunthanger.com/smf/open-forum/os-la10-useful-or-not/
« Reply #3 on: September 09, 2016, 10:03:58 AM »
Hi Tim san,
Aki
Thank you Aki san.  That is exactly what I needed -- I have metal and plastic, I have a lathe, I have enough skill to make a venturi.  I just didn't have a clue of what sized hole I needed to make!!
This should get me on the road.
« Reply #4 on: September 09, 2016, 10:48:59 AM »
sheesh Tim, its easy, make it the proper size,, the size that promotes proper suction, proper mixture, and atomizes the fuel properly,, how hard is that, LOL D>K H^^
« Reply #5 on: September 09, 2016, 01:46:06 PM »
Oh thank you Mark.  I'll just look in my drill index for one marked "the right size" and use that.  Why didn't that occur to me before?
Offline Geoff Goodworth
« Reply #6 on: September 09, 2016, 10:53:30 PM »
Aki's comments are correct re the spraybar. However, I've run mine using an APC 8 x 4 and it seems like a powerhouse.
