  • June 24, 2025, 07:03:38 PM
Author Topic: Re Head McCoy 35 Needle Setting  (Read 958 times)
Offline Ronald Eshleman
« on: May 25, 2010, 08:09:38 PM »
Can someone tell me where to set the needle valve on a red head McCoy 35 probably from the 50's or 60's? I just inhereted this beauty but it won't run long enough to get started and adjust at 3 and a half to 4 and a half turns.  I'm using powermaster 29% fuel.
Offline philip metzner
  • chevyiron420
Re: Re Head McCoy 35 Needle Setting
« Reply #1 on: May 25, 2010, 08:43:12 PM »
I havent run my red head in a long time and i dont remember exactly, but i dont think it was more open than usual. My caution is about your fuel. Im not familiar with powermaster 29%. Do you mean 29% oil or nitro? I would make sure that your fuel is heavy on oil and that its all castor and i dont think you need more than 10% nitro, maybe less.
Offline kenneth cook
« Reply #2 on: May 26, 2010, 05:12:33 AM »
         Ronald, I purchased the Powermaster .29% for the same purpose as you just mentioned, for my older style engines. These engines like around 10% nitro which is what I bought. I will say it worked but not as expected. I had all Fox plugs in my redheads and older  K&B engines. I think that was my problem. The plug was virtually drowning in the oil as it would start fine then when I would go inverted the engine would quit. This also happened when I used this fuel in my OS Max-S. I switched to a hotter Thunderbolt plug and this was resolved. Just keep a fairly rich setting on the ground and pick the nose up until it breaks and that should be fine. I wouldn't let that engine turn up too much as an overlean run will more than likely do damage to that engine. They do work and run well. I have some that I wouldn't part with as they're very reliable. Make sure the spraybar is clear as they're brass and they will get clogged with the green goo. a straight pin through it and a good fuel flush takes care of that. A 10x6 prop is a good choice for the .35 as well.  Ken
« Reply #3 on: May 26, 2010, 08:06:59 AM »
Ronald  Try this, it works on every motor.Make sure needle valve spray hole is clear. Connect a short piece of tubing to needle valve and blow threw it turning the needle  until you feel resistance to the air flow. That setting will be very close. If you motor will not keep running more than likely the spray hole is plugged.
« Reply #4 on: May 27, 2010, 12:39:17 PM »
I second what Ken said. They do need a hot plug or they just quit. I run 5 McCoy 35's, and they all run very well on an APC 10-6 prop, and Thunderbolt R/C long plugs. Should run well on K&B R/C long, Sig R/C long, Glo-devil 300's, and most other hot plugs. Also, check you backplate screws for tightness. If the backplate leaks, they don't run well.
