  • July 18, 2025, 07:47:45 PM
Author Topic: Fuel capacity PA 51  (Read 1472 times)
Offline Paul Allen
Fuel capacity PA 51
« on: January 04, 2021, 01:03:59 PM »
Looking for setup tips for a PA 51 RE on muffler, how much fuel (5% nitro) and tank height
with engine sitting on 1/8" steel pads off the bearer, motor inverted.
Offline Alan Buck
Re: Fuel capacity PA 51
« Reply #1 on: January 04, 2021, 03:00:08 PM »
Hi Paul   go with 6oz tank  you can pull some out if needed
ALAN E BUCK
« Reply #2 on: January 04, 2021, 09:07:12 PM »
I burn  6 ounces  with my Katana/PA 51  , it is sitting on the beams, but  my uniflow  is  moved,  If I had  1/8 pads  I would  need to move the tank  off the beam. You need  to  dial yours  in but try to move a 1 inch tank  1/8 inch off the mounts  to start
Offline Paul Allen
« Reply #3 on: January 05, 2021, 12:47:14 AM »
Thanks Randy and Alan.
In OZ
