  • June 20, 2025, 02:54:10 PM
Author Topic: Fuel Bad??  (Read 2316 times)
Offline Bootlegger
Fuel Bad??
« on: May 03, 2016, 11:59:48 AM »
 A friend is having trouble getting engine runs with some old fuel.  What can we check to see what is wrong with it, Water or whatever?  :X  :X
 It runs alright on other fuel..
 Thanks..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dan Berry
Re: Fuel Bad??
« Reply #1 on: May 03, 2016, 12:15:22 PM »
Try new fuel.
Re: Fuel Bad??
« Reply #2 on: May 03, 2016, 12:28:54 PM »
Sounds like your friend has found the problem.  That was easy.  Now, how about a hard problem.
Offline Terry Caron
Re: Fuel Bad??
« Reply #3 on: May 03, 2016, 03:42:04 PM »
If maybe your friend has lots of the old stuff and doesn't want to just throw it out, here's something I found somewhere
sometime about water contamination:
"Try digging up an hydrometer, maybe at a brewing supply store.  Pure methanol has a specific gravity of .7913.  It goes up when water gets in it, so any change in the reading is likely enough to cause problems.  Each .0001 change is about 1/10 of 1%."
You can borrow mine if you want to come get it.  ;D
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Online Jim Kraft
Re: Fuel Bad??
« Reply #4 on: May 03, 2016, 04:11:10 PM »
Sometimes old fuel with castor in it gets congealed and makes flakes in the fuel that do not flow through the spray valve very well. I have taken old fuel and strained it through a paint filter to clean it up and it works fine. Sometimes just setting the jug, if it's plastic, out in the sun will dissolve it back into the fuel. But the paint filter works best. I have run fuel that was 10 years old after filtering it.
Re: Fuel Bad??
« Reply #5 on: May 03, 2016, 07:41:45 PM »
The real solution, IMO, is improved "fuel handling" techniques. Any system that keeps the jug as air tight and waterproof as possible is what you want to work toward. Opinions vary on how best to do that, but Brett says to fill the fuel tank and suck out excess fuel to get to the correct fuel load for your plane/engine for that day.
Brett doesn't like the "mayonnaise pump", but I do. Each stroke of mine (after priming the pump) gives exactly 1 oz. If I need 5.75 oz in my clunk tank, I pump in 6 oz  and pull out 7cc's with a 1 oz syringe, and squirt it back into the jug. The difference here is that the clunk tank does not work with "cutoff loops", so it's always quite consistently emptied, unlike a typical metal tank. Relative to the subject at hand (water in the fuel), very little time is spent with the fuel opened to the atmosphere.
Also, fuel filtering is only done in one direction...many guys will suck fuel into a syringe through a filter and then blow it back into the tank through that same filter, but the other direction. Easy to see that what crap was initially caught in the filter is then pumped into the fuel tank. That's not good!  n1 Steve
