  • June 15, 2025, 02:06:18 PM
Author Topic: Fuel and prop for Stalker .46 re?  (Read 1699 times)
Offline frank mccune
« on: June 18, 2021, 01:05:32 PM »
         Is a fuel mix 11-11 oil, 5 nitro and a 10-6 prop a good set up for a Stalker .46?
          Is there a better choice?
          Tia,
           Frank
Offline Manuel Cortes
Re: Fuel and prop for Stalker .46 re?
« Reply #1 on: June 18, 2021, 02:40:48 PM »
Hi Frank.
IMHO the fuel is ok.
I would try a 11x6 or 11,5x6....better than the 10".
Kind regards from Spain.
Manuel Cortés.
Kind Regards.
Manuel Cortés.
Offline Brad LaPointe
« Reply #2 on: June 18, 2021, 03:14:43 PM »
I use no nitro ,20% synthetic and the rest methanol. 11x6 or 12x6 . Too much castor is not a good idea for this engine as per my own experience.
Lots of torque in these engines, big props and low rpm works very well with them .
Brad
Offline Craig Beswick
« Reply #3 on: June 18, 2021, 03:25:09 PM »
Hey Frank,
Stalker engines, all synthetic NO Castor NO nitro.
At least to start with.
Craig
AUS 87123
"The Ninja"
« Reply #4 on: June 18, 2021, 04:52:02 PM »
       Thanks for all of the replies!
        Frank
Offline Brian Gardner
« Reply #5 on: June 19, 2021, 09:12:00 AM »
As others have suggested 20% synthetic oil. You can use 11/11 but the bore is likely to varnish.
11x6 is a good starting point.
Although they are designed/intended for no nitro - you can run it, but if it gets a bit difficult to tune you'll want to add head shims until it settles.
