Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 15, 2025, 08:46:52 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Fuel and prop for Stalker .46 re?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Fuel and prop for Stalker .46 re? (Read 1702 times)
frank mccune
AMA Member
Trade Count:
0
Admiral
on:
June 18, 2021, 01:05:32 PM »
Is a fuel mix 11-11 oil, 5 nitro and a 10-6 prop a good set up for a Stalker .46?
Is there a better choice?
Tia,
Frank
Logged
Manuel Cortes
Trade Count:
0
Commander
Re: Fuel and prop for Stalker .46 re?
Reply #1 on:
June 18, 2021, 02:40:48 PM »
Hi Frank.
IMHO the fuel is ok.
I would try a 11x6 or 11,5x6....better than the 10".
Kind regards from Spain.
Manuel Cortés.
Kind Regards.
Manuel Cortés.
Logged
Brad LaPointe
24 supporter
Trade Count:
0
Commander
Reply #2 on:
June 18, 2021, 03:14:43 PM »
I use no nitro ,20% synthetic and the rest methanol. 11x6 or 12x6 . Too much castor is not a good idea for this engine as per my own experience.
Lots of torque in these engines, big props and low rpm works very well with them .
Brad
Logged
Craig Beswick
25 supporter
Trade Count:
0
Captain
Reply #3 on:
June 18, 2021, 03:25:09 PM »
Hey Frank,
Stalker engines, all synthetic NO Castor NO nitro.
At least to start with.
Craig
Logged
AUS 87123
"The Ninja"
frank mccune
AMA Member
Trade Count:
0
Admiral
Reply #4 on:
June 18, 2021, 04:52:02 PM »
Thanks for all of the replies!
Frank
Logged
Brian Gardner
Trade Count:
0
Captain
Reply #5 on:
June 19, 2021, 09:12:00 AM »
As others have suggested 20% synthetic oil. You can use 11/11 but the bore is likely to varnish.
11x6 is a good starting point.
Although they are designed/intended for no nitro - you can run it, but if it gets a bit difficult to tune you'll want to add head shims until it settles.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
