  • July 09, 2025, 03:34:50 AM
Author Topic: Frozen engines  (Read 11079 times)
Offline James C. Martin
Re: Frozen engines
« Reply #50 on: April 27, 2014, 07:27:48 PM »
have found the easiest way is to pre heat the oven to 350 and borrow one of the wifes cookie sheets and bake them for about an hour thnn cool slightly handling them with oven mits and some penetrateing oil and they free right up
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
Re: Frozen engines
« Reply #51 on: April 28, 2014, 05:34:38 AM »
Nice job! Any stuck engines I get, I just soak them in paraffin. (If you can remove the cylinderhead and backplate prior to this all the better).
Tim
Re: Frozen engines
« Reply #52 on: April 29, 2014, 05:08:37 PM »
Crock Pot?  I don't need no steenkin' crock pot!  A small electric hot plate and a Pyrex bowl is all I use.  It works just as good as a crock pot.  The engine doesn't know the difference!
Offline Andrew Tinsley
Re: Frozen engines
« Reply #53 on: April 30, 2014, 08:55:35 AM »
Just a mention that all frozen engines need not be "Frozen"! I was given an Elfin 2.49 diesel (the second Elfin that I got hold of recently. Not a lot of the usual things worked, but I eventually got the piston out with a wooden drift!
I cleaned everything up and oiled the piston and slid it into the liner. The piston top got as far as the exhaust ports (360 degree radial ports in the parlance of the day), it then stuck solid! The liner must have been distorted in a crash and there isn't much meat in the pillars separating the radial ports!
I am now considering if I can hone the bore out oversize and make a new piston. I am a sucker for basket case engines!
Andrew.
BMFA Number 64862
Offline Mike Greb
Re: Frozen engines
« Reply #54 on: May 04, 2014, 02:32:14 PM »
I have a completely frozen fox 35
Online RandySmith
Re: Frozen engines
« Reply #55 on: May 04, 2014, 06:57:02 PM »
1/2 hour in a 190 degree crockpot  will fix your frozen FOX !!
Offline James C. Johnson
Re: Frozen engines
« Reply #56 on: June 02, 2014, 06:13:46 PM »
Here is a trick no one has mentioned... I had a ASP 46.. it was so frozen the piston wouldn't move with no amount of heat.. so.. I resorted to my last resort ...bear in mind the bearings were filthy... I heated the engine on the gas stove ... and then immersed it in acetone... the liner broke free and came right out.. the amount of dark sludge came pouring out of the engine... Rule #1 for using this stuff is you need air "escaping" at the top of the piston.. I put oil on the piston and heat it up.. you will see bubbles ... This engine was crock potted and the piston still would not budge.. acetone broke it free instantly... This tip comes from Bob Allen of Enya Fame... read this link... I was amazed. I rebuild or refurbish about 200 engines a yr..
JJ
http://www.supercoolprops.com/articles/sticky_situation.php
