  • July 14, 2025, 03:02:42 PM
Author Topic: Front Ball Bearings  (Read 5971 times)
Offline Garf
    • Hangar Flying
Front Ball Bearings
« on: March 18, 2006, 04:07:34 PM »
When I used to fly combat, a LONG time ago, we used to replace the open front bearing on the Super Tigre engines with a shield one side bearing. We figured we needed all the protection from dirt as we could get. Going thru my G21 .46's,
I would like to do the same. The shield one side bearing is hard to find, so I usually remove one shield from a shield 2 side bearing. Since the shields don't seal, There may be no reason to remove the shield at all. Does anyone have any experience using shield 2 side bearings?
Re: Front Ball Bearings
« Reply #1 on: March 18, 2006, 08:14:43 PM »
Hi Phil,
I always remove the inner shield since Boca suggests that on the bearings I get.  Never tried it without removing it.
Offline Garf
    • Hangar Flying
« Reply #2 on: March 18, 2006, 09:22:56 PM »
I usually do that, but the last batch I got used snap rings to retain the shields.  It was a real problem to remove them.
« Reply #3 on: March 19, 2006, 05:21:41 PM »
I haven't run into the snap ring retainers yet.  What engine are they for?
Thanks!
Offline Garf
    • Hangar Flying
« Reply #4 on: March 19, 2006, 06:51:41 PM »
Super Tigre G21 .46
« Reply #5 on: March 20, 2006, 11:07:22 AM »
Hello
It is best on the ST 46 to use a  607 2-RS  sealed bearing NOT shielded bearings,
Just remove the inner rubber seal from the bearing with a  T_pin
Offline Garf
    • Hangar Flying
« Reply #6 on: March 20, 2006, 09:04:45 PM »
Doesn't that prevent oil flow thru the bearing?
