  • June 19, 2025, 05:40:05 AM
Author Topic: FP 40 gone wild  (Read 18050 times)
Offline Chris Fretz
FP 40 gone wild
« on: July 08, 2017, 05:27:47 PM »
So I bought a FP 40 used and threw it on a airplane, thought it vibrated more than it should.  Flew it and it just ran away wild.  I've seen on here about adding a head gasket. So I pull the head gasket of the motor and  put on a different FP 40 that was R/C. Took the needle and venturi off, the venturi was .290. I've read to use a FP 20-25 venturi. I've got a new one laying around, it measures .260. So I put that on.  It has a 843 muffler, maybe I should of used a 892. I have no idea what the right muffler is.  Both FP 40s are the steel ones. Anyway I set the needle right when the engine starts to break and about 1 or 2 laps and it runs away wild too. Engine runs out of spunk in the stunts running lean.  Basically the head shim and smaller venturi didn't do anything different. What can I do now to tame it?
I've got 2 FP 40 abn engines as well,  I assume they run wild as well?
I could chuck up the head and remove materal but I have no idea how much...
Chris
Formerly known as #Liner
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #1 on: July 08, 2017, 05:37:13 PM »
DO NOT cut up your engines.
What prop (brand, model, diameter, and pitch)?  What fuel?  What launch RPM?
I was just flying with a Tower 40 today, which as far as I know is an FP clone.  It flew great on an APC 11-4 and some Omega 10% Nitro that's been doctored up with some extra castor oil to bring the oil content up to 22%.
If you try to run an un-modified FP like a Fox 35, with a 6-pitch prop and a 2-4-2 break, then it'll run away every time.
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #2 on: July 08, 2017, 05:47:21 PM »
APC 11-4, 10% 11.5 11.5 Brodak fuel. I didn't tach it, I just cranked it up till I heard it break.
AMA 1104207
Advanced
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #3 on: July 08, 2017, 06:03:46 PM »
I just fired it up and it was sitting around 9800-9900. What are you launching yours at? I'm running muffler pressure as well.
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #4 on: July 08, 2017, 06:11:51 PM »
So I bought a FP 40 used and threw it on a airplane, thought it vibrated more than it should.  Flew it and it just ran away wild. ....
<snip>
<snip>
    That's just what they do, time after time. I despise 40FPs for many reasons, but mostly because the "engine rework industry" was kept alive by people trying to get 40FPs to run properly (and usually failing in one way or the other).
   My advice - sell them to an RC guy and use the money to buy an Aero-Tiger.
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #5 on: July 08, 2017, 06:54:12 PM »
Well that's no help,  I wanna tear up the skies tomorrow with the old girl. Maybe I can put a pair of pantyhose or two on and not run for 20 minutes on 4.5oz's. Someday I'm gonna bring back the LA 25 post too cause I can't get a stock one to not be a disappointing dog either.
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #6 on: July 08, 2017, 08:03:11 PM »
Chris
What needle  are  you using?   Do you have a tongue muffler that will fit it?   Fuel  ?  are you sure the crankshaft is straight?
Re: FP 40 gone wild
« Reply #7 on: July 08, 2017, 08:13:45 PM »
So I am wrong in thinking that they're similar to the Tower 40?
Maybe the answer is to sell 'em on eBay and get one or two 46LA's -- which are known-good.
Re: FP 40 gone wild
« Reply #8 on: July 08, 2017, 08:17:08 PM »
On my Tower 40, and my 46LAs, I launch at somewhere between 9600 and 9800 depending on the plane.  If they run away, I put on pantyhose and launch at a speed that'll get them through the pattern.  If they thin out at 45 degrees and in the overheads, I remove pantyhose and try again.  Eventually this stopped working on the Tower 40, but a night in the crock pot with some antifreeze cured that very nicely.
If Brett's right, though, you're out of luck -- I can't say, because the only 40FP I have is on a carrier plane.
Re: FP 40 gone wild
« Reply #9 on: July 08, 2017, 08:18:51 PM »
You didn't say what plane.  I'm using an APC 11.5-4 on my Tower 40, and a ThunderTiger 11x4.5 (which is more like 11x4) on one of my 46LAs, and an APC 11.5x4 cut down to 11.25x4 on the other.
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #10 on: July 08, 2017, 08:49:17 PM »
A stock OS needle, 20-40 FP .135 thick spray bar. I do have a couple tongue mufflers around.  Brodak 10% 11.5 castor 11.5 synthetic. Both used 40FP I have tried vibrate a bit.  Cranks appear to be straight.
Chris
AMA 1104207
Advanced
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #11 on: July 08, 2017, 08:51:15 PM »
ARF Primary Force, where do you get thunder tiger props? I can't find them anywhere.
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #12 on: July 08, 2017, 09:37:02 PM »
If This Dosnt Cure My FSR , I'll tear its head off .  :-\ :-X :(
Said to MAINTAIN SQUISH BAND CLEARANCE Whilst Lowering C.R.
the clearance is required for the shock wave for the turbulance for the mixing / C R ' Shock ' , at t d c .
Tho OS FP injun tests on sceptre flight , the Combustion Chamber Volumes are differant , C/L to R.C.
So Presumeably the R C head & the C L head are NOT the same ?? on the FP 40 .
any comparisons there ?
Re: FP 40 gone wild
« Reply #13 on: July 08, 2017, 10:31:12 PM »
Chris,
Bob Z also posted a similar picture of his mods to the FP.40 head, so you can compare the two if you can find it. He posted it within the past year either in the open, or more likely the engine forum. It changed mine in my full fuse Oriental from running away after the first few stunts, and it ran a nice dependable 4-2 after that. You don't have to run it with a 4-2 break, I don't believe it was intended to anyway. FPs are notorious for running great on every flight except officials.
Mine had a stock FP.25 venturi and NVA. I ran an APC 10-1/2 x 4-1/2 prop with 10/22 Powermaster fuel. Tongue muffler an extra row of holes and pressure to the uni vent. Adding head gaskets did nothing to improve mine before I gave up and turned it over to Bob.
Rusty
EDIT: I found the picture he gave me, and that is it above in Matt's post.
Offline Target
  • C/L Addict
Re: FP 40 gone wild
« Reply #14 on: July 08, 2017, 10:51:12 PM »
My buddy reworked my fp40, and it starts on the first flip, never runs away,  and 4-2-4's perfectly.
I believe he changed the timing a little,  added a shim,  and puts on a (I think) .240 venturi. It's got an ST nva. Edit- this engine has a .256" venturi.
Whatever he's done,  it works. Launch is in a mode between 2 cycle and 4 cycle, and we are running a  uni-flow tank.
Hope you get yours sorted.
R,
Chris
« Last Edit: July 09, 2017, 11:30:46 PM by Chris Behm »
Chris
AMA 5956
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #15 on: July 09, 2017, 12:48:36 PM »
Perfect just what I needed thanks!
AMA 1104207
Advanced
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #16 on: July 09, 2017, 12:50:11 PM »
Chris,
Rusty
Good to know Rusty thanks! Do you know with your head mod still has the extra head gasket or just one now?
Chris
AMA 1104207
Advanced
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #17 on: July 09, 2017, 12:53:07 PM »
Some R/C guy is gong to be sad to know there is one less stock 40FP head left in the world. Pantyhose didn't help so screw it, in the lathe she went.
Sent from my SM-G920V using Tapatalk
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #18 on: July 09, 2017, 02:23:12 PM »
Chris
The 290 venturi with a FP 20  needle  is  WHOPPING  TOO  big.. This is the equivalent of about a 325 Venturi . The normal OS NVA  diameter was .157  before they started to  use the  FO 20 Needle, you should  try a  255 to 260 venturi  maximum .
The ones I set up, and I have setup over 300 of them use that size, if you use a PA, ST , Enya, OLD OS  Needle assembly  use a  280 venturi .
 The STOCK head does NOT need to be cut, This is normally just a way to reduce power by cutting the compression out of it   , it works very well as is  with 1 or 2 head shims, it needs no more.
I use a  11x4.5 ,  11x4, 12 x 4  11.5 x 4.5  prop, 5 or 10 % nitro  and 20% oil fuel with at least 1/2 synthetic oil.
In many ships this setup will launch about 10,7 to 11,100 RPMs, launch in just barely a 2 stroke or cackling back in forth in  4-2
The engine will unload and richen as the first lap goes... if it does not check your tank,  Do NOT run pressure, or the  742   muffler, Use a tongue or  open tube type that has an exhaust of at least 310 ID
Also  it is not normal  to  have that much vibration, the most common cause of this is a slightly bent crank, and  no  you cannot see it with your  eye. You need to check the run out with a dial indicator
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #19 on: July 09, 2017, 03:08:23 PM »
Do you have a picture of the set up to check it with a dial indicator?
Chris
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #20 on: July 09, 2017, 04:25:40 PM »
Chris
Just one.
Re: FP 40 gone wild
« Reply #21 on: July 09, 2017, 11:21:52 PM »
    RC and CL are the same part, including part number, as is the case with almost all of these engines. Virtually all of these engines are exactly the same as the RC version, with the carb removed and venturi put in.
    Excess compression can cause many problems, but "running away" is not one of them.
   By the way, "running away" is a misnomer. The engine is running *exactly as designed*, and if you try it on an RC carb, you can easily see it has absolutely no problem running at even 2000 RPM with stock compression.
   The solution to excess speed is clear- run it at reduced throttle (i.e. a much smaller venturi). Then, you will see if there is any secondary problem with maneuvering. Of course, there is a still easier solution - since you only need about half the power of a 40, maybe you need a 20. And a 40FP will require a *much smaller* venturi for the same amount of power than a 20FP.
    The suggestion of a .240 sounds like it could be about right, and I recall people using as little as .225.
Offline Target
  • C/L Addict
Re: FP 40 gone wild
« Reply #22 on: July 09, 2017, 11:28:55 PM »
Brett- just for the sake of accuracy,  my buddy that set up the FP .40 says my engine has a .256 venturi (with the .156" ST needle valve running through it.
Boost port not blocked.
R,
Chris
Chris
AMA 5956
Re: FP 40 gone wild
« Reply #23 on: July 09, 2017, 11:47:37 PM »
    That's about the same as a .240 with a 3.5mm/.138 spraybar, which sounds like it is about right.
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #24 on: July 10, 2017, 12:55:08 PM »
Anybody know how you check for a bent shaft? I could put a dial indicator on the end of the prop shaft and turn the motor through but it's not going to be much of a reading bouncing up and down on the threads.
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #25 on: July 10, 2017, 02:00:07 PM »
I'd like to know too. we have a professional machinist amongst our regular video hangout members, so I'll bring it up in tonight's session. I would guess it'll amount to something like chucking it in a precision milling machine and using a sensitive gauge to feel and measure it as it's hand turned through a revolution.
Re: FP 40 gone wild
« Reply #26 on: July 10, 2017, 04:53:03 PM »
Yes  I spin  mine, by hand on the lathe, or setup in bearings,  and then use the 1/4 x 28 sleeve I turned over the threads , or I use one of my Spinner couplers (that are cnc and true)  over the threads, then just slowly turn it with the dial indicator on it.
Other way is to chuck up the entire front threaded part and indicate off the of the main journal
If I get time I will try to take a photo
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #27 on: July 10, 2017, 06:37:50 PM »
So something like this with a snug fitting sleeve?  I get about .001 spinning the engine through on both my 40FP.
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #28 on: July 10, 2017, 10:09:18 PM »
Maybe Randy can tell us what an acceptable tolerance is. Do you get any change when you apply side pressure back and forth?
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #29 on: July 11, 2017, 02:50:58 AM »
One of the 2 has a bit of a sloppy shaft bushing, I think it was about .010-.015, probably some jerk that didn't balance his props.
« Last Edit: July 11, 2017, 03:39:38 AM by #Liner »
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #30 on: July 11, 2017, 09:44:12 AM »
Hi
001 run out will not make it vibrate and is OK, that said  , with that much bushing slop you cannot  test it that way, you would need it out of the  case. I assume you are keeping the  motor still and turning the crankshaft?
If you test that way you would need to remove the head, and try to spin the crank consistently without moving it up down or side ways in the bore, also if you have any drag in the piston sleeve then remove it too before testing
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #31 on: July 11, 2017, 10:08:11 AM »
Hi
Yes keeping the motor still and turning the crankshaft. I had noticed the crank pressure caused the rod to push on the crank giving an inaccurate reading,  I just turned it slow to keep it from  pushing the crank up and down.
What is an unacceptable amount of bushing slop? What is an unacceptable amount of run out?
Chris
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #32 on: July 11, 2017, 10:10:26 AM »
Hi
      I am far from an aerospace machinist but I would be tempted to remove the crank, put the thread in a 1/4" collet, then put the dial indicator on the smooth part of the shaft. That will tell you if the crank is bent WRT the threads.
    What it won't tell you is if the plane of the drive washer it perpendicular to the crank, which might be just as important.
Re: FP 40 gone wild
« Reply #33 on: July 11, 2017, 10:18:25 AM »
   You will get plenty of arguments about that. My observation, for what it is worth, is that at least some aspects of the 4-2 brake are greatly improved as the bushing loosens up, and the best seem to be with alarming amounts of slop (like 1/8" or more of slop at the prop tips). With very tight bushings, they tend to "smear" back and forth from 4-2 and even more so, from 2 to 4, where when they are very free, it's like flipping a switch. The Discovery-Retro, while ball-bearing with no detectable slop, it also astonishingly free through the slack portion of the rotation. The only way you get that with a bushing is with a lot of slop, because tight fits = lots of oil drag.
    It was almost an article of faith that the Fox 35 was best after you were on your 3rd piston/liner, because by then, you had enough run time on it to get the bushing sufficiently worn.
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #34 on: July 11, 2017, 10:22:14 AM »
Why not indicate the front of the drive washer wile in the collet then?  Good idea though, I always forget about collets.
Chris
« Last Edit: July 11, 2017, 11:35:00 AM by #Liner »
AMA 1104207
Advanced
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #35 on: July 11, 2017, 10:26:55 AM »
All 7 of my Fox 35's have a ton of bushing slop. I wouldn't be surprised if there wasn't a lot when brand new.
I use to just a engine at a swap meet by how much bushing slop it has, and still do. Maybe I shouldn't worry about that anymore.
Chris
AMA 1104207
Advanced
Offline Fredvon4
  • Central Texas
Re: FP 40 gone wild
« Reply #36 on: July 11, 2017, 10:54:37 AM »
Because I do have a good dial indicator but no good way to fixture these cranks to check run out.... I have never tried
BUT if I did, I would probably gut the engine down to only the crank and bearing(S) ...super clean and dry, then very slight coat or ARO and indicate off front drive washer that the OD should be concentric with a prop tightened down
last year, I had one engine that vibrated a lot more than I thought was right >>>compared to several other of same lineage
I set to get one good prop properly balanced and each tip in plane....convinced myself the hub was flat and square to the blades
This was on an Enya 5224 .35 with collet compression drive washer.... tried several different prop clocking and still vibrated
When I checked for the prop tips in plane, now on the engine, I discovered the drive washer was not perpendicular WRT the crank shaft...swapped drive washers and vibration went away.....
FWIIW I now have a robust collection of OS LA/FP/FX engines from .20 to .46 and so far all of them seem to run the smoothest of any of my other similarly sized engine brands
BUT a year ago I did a bench run with brand new APC prop one time with a NIB OS FP .25, and learned a lot about a badly out of balance prop.... OR was it that horribly off center placed drill hole....hummmm
Yes Virginia I did remove the sticker and glue
and yes, NOW I do check the balance and correct for all my to be in use props
Funny how for years I got away with never balancing a Top Flite/Torpedo/Grish 1/2a prop or any Rev Up .35 / .36 combat engine propellers
Fred von Gortler IV
Re: FP 40 gone wild
« Reply #37 on: July 11, 2017, 12:23:51 PM »
Chris
Hi Chris
The bushing should have no more than .005 thou slop on a OS FP, they have less when new and run very well, as far as how much runout, I would not use the crank if it has more than .003 to 4 thou
Still, as I said the best way to test is to remove the crank, and test it that way, you can also load the drive washer with spacer rop washer nut  and test the  runout on it  too, I would put the spinner back plate on just to  have another point to run the dial indicator on
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #38 on: July 11, 2017, 04:25:56 PM »
Hi Chris
Thank you for the information Randy!
I assume the same tolerances apply for the LA series engines?
Chris
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #39 on: July 11, 2017, 08:05:22 PM »
Crank Out and between centers'd sound like the way .
Liner - one often sets the " Squish Band Clearance " or at least measures it . Just Depth to Piston at TDC , minus amount of head ' pluged in ; .
About 10 Thou, on a .40 .
Just aword on the Venturie Dia Issue . Altitude & Temperature .
A Magnum 40 ( Identical bar spraybar Posn ) at 3.000 somethingas altitude and 30 + degrees , drilled the straight thru / pherical jet
factory thing out to 1/4 in , for adequate oomph .
Back in NZ at sea level Temp around 15 , About 80 mph was the result .
Somebody talks of ' Tuning ' to site ( Comps ) by changing Venturie so Needle Stays The Same Setting .
Anyway , Venturie Dia Equates to Atmosphereic Density . The Red Sea isnt going to be the same as pikes peak .
Re: FP 40 gone wild
« Reply #40 on: July 11, 2017, 08:07:08 PM »
looks Marvelous . theres half a dozen heads in the mail on the way .  ^-^
Re: FP 40 gone wild
« Reply #41 on: July 11, 2017, 09:04:37 PM »
I know I am going to regret this, but can anyone explain why you think lowering the compression will keep the engine from running away?  Compression has pretty predictable effects:
   more compression  = more power, bigger difference between 4 stroke power and 2-stroke power (stronger break), faster transition from 4-2 and 2-4
   less compression = less power, less difference between 4 stroke power and 2-stroke power (weaker break), slower transition from 4-2 or 2-4
   too much = misfiring, random quitting
   none of which seem to apply here. If you assume it's a compression problem, if anything, it doesn't have enough compression - it breaks to a 2 and *never* comes back.
     It's also clear that the engine would run fine as slow as you wanted if you had a throttle on it, also suggesting that the compression is OK even at low revs. If not, it would be a fuel suction issue - again not the compression.
    If the issue is too much power with a still-needleable system, you would want a smaller venturi, not less compression. If the system is *not* needleable, then you *still* need a smaller venturi (and possibly a change to the lateral tank position, i.e. you are trying to suck fuel too far uphill on a profile with a 2" wide tank, or it's too thick).
   It's running too fast.  The most direct solution is to reduce the power and increase the fuel suction. So no matter how you cut it, to first approximation you need a smaller venturi, not a lower compression head or 50 head gaskets, etc.
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #42 on: July 12, 2017, 03:53:44 AM »
Are you asking me? I just read a bunch of people had problems with the engine and everyone's cure was a extra head gasket or if that didn't work getting the head machined. I have 4 of them and I'm willing to give anything a try when I run out of ideas. I really have no idea what more or less compression does. I'm just trying what has worked for others, if it don't work for me I just waisted my time and move on to something else. I think most of my problem is a weak fuselage causing vibration.
After running the engine with a machined head it seemed to be breaking from 4-cycle to 2-cycle at 8300rpm so that seems to be following what your saying.
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #43 on: July 12, 2017, 08:11:36 AM »
tHE vast  MAJORITY   of problems of OS 40 and 35 fps came from   TOO  large  a venturi, OS swapping the .157 diameter  Needle assembly out for a 20 size assembly at .135 or so, and then putting out a muffler (742) that was extremely restrictive .  It had nothing to do with over compressed head.
The same problems plagued the  LA series , I cannot tell you how many people I have seen trying to use the  tiny OS FP  Needle  assembly with a 290 venturi,The  problem with this is it is massive in size and equates more like a .325 venturi  with the tiny needle assembly , all the above cause  runaway and low fuel suction, and will almost  never be  stable.
If your going to use the  tiny  OS 20 NVA  you need to use  a 250 to 255  venturi  max. or use  a more standard size , Old OS , Enya, ST, PA  etc  that are all .157,  with this size NVa  you can use  a  .275-.285  , The  tweek from there .
Other things that help  are a solid motor mount, stiff frontend, well made tank mounted to help minimize vibration, keep the tank close to the  engine, stay away from muffler pressure, use a good fresh fuel with mostly synthetic oil, or at least 1/2 synthetic oil, of at least 20% total (22 seems to be used by most)  , use nitro that fits what the weather is..don;t under or over nitro your fuel , use what is needed... too much is not better...too little is not better   try to alway use fuel filter on the feed line
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #44 on: July 12, 2017, 08:31:18 AM »
Randy could you show me a good example of a padded tank mount that will minimize vibration for a profile?
Chris
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #45 on: July 12, 2017, 08:53:05 AM »
... I cannot tell you how many people I have seen trying to use the  tiny OS FP  Needle  assembly with a 290 venturi,The  problem with this is it is massive in size and equates more like a .325 venturi  with the tiny needle assembly , all the above cause  runaway and low fuel suction, and will almost  never be  stable.
If your going to use the  tiny  OS 20 NVA  you need to use  a 250 to 255  venturi  max. or use  a more standard size , Old OS , Enya, ST, PA  etc  that are all .157,  with this size NVa  you can use  a  .275-.285  , The  tweek from there ...
I'm no Randy Smith, but I can personally attest to the whole thing about a too-large venturi causing runaway on an OS (or Tower) motor.  I've had it happen to me.  You get it slowed down well past its natural speed on the ground by running it rich, you launch, and either in the first few laps, or after you've been at 45 degrees a few too many times, it "hits the step" and jumps from 5+ second laps to 4.5 second or less.  It's the basis of the tuning procedure that I outlined close to the top of this thread, which is only different from what someone like Randy might advocate in that I prefer to use layers of nylon mesh instead of a handful of different venturis to arrive at the right venturi size.
I think the only place where I really differ from Randy is purely a matter of personal preference -- he likes to use a 0.157 needle; I just hate having a motor that's had holes drilled out, so my tendency is to make a venturi of a size that's proper for the OS needle assembly, and run with that.
But he's telling you pretty much the same thing I was.
Dang.  Now I need to go get a 40FP and give it a whirl in a plane...
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #46 on: July 12, 2017, 10:05:43 AM »
I'm reluctant to drill mine out as well. However lately when I see 1 click almost change 300rpm I think it might be nice to have a more fine adjustment. Looking on "list your LA46 setup" almost everyone is using a PA needle valve.
AMA 1104207
Advanced
Offline Target
  • C/L Addict
Re: FP 40 gone wild
« Reply #47 on: July 12, 2017, 04:14:33 PM »
It's only @ .010" off each side of the hole. Practically nothing. So much easier than what you did (a beautiful job of) putting the head on the lathe, for sure.
It's worth it alone for having a needle valve without "clicks" at all. We like the Brodak NVA's as well.
Any needle valve with an adjustable tension collet on a smooth needle is awesome, they seal wonderfully and have infinite adjustment. Just what you want in a needle valve.
DO IT! :-)
Hope you come back with a happy result!
Try my sized (.256") venturi and the .156" NVA, and see what happens. I believe we are running 8% nitro, and 11/11 oil, so aim for 5% or 10% nitro with that same venturi and needle and your results should be close.
Chris
AMA 5956
Offline Chris Fretz
Re: FP 40 gone wild
« Reply #48 on: July 12, 2017, 08:14:39 PM »
DO IT! :-)
Thank you! I'll hack up a 40FP without much heartache, buuuut I have a hard time cutting up my beloved LA46's. They seem to have increased in price a lot on eBay lately. Plus then I have to turn around and buy all new needle valve assemblys. This hobby will make you broke fast.  Maybe just maybe I'll take the giant leap in the near future and try one but I may need someone to pull the trigger on the drill for me %^@
Chris
AMA 1104207
Advanced
Re: FP 40 gone wild
« Reply #49 on: July 12, 2017, 09:53:33 PM »
Chris
If you're handy with that lathe you can make your own needle assemblies.  Just sayin'...
