  • June 20, 2025, 04:20:56 PM
Author Topic: FP 40, Does adding a head shim help tame the run away?  (Read 12291 times)
Offline Allen Eshleman
« on: January 01, 2014, 09:21:24 AM »
I have an NIB FP 40, to possibly go in a Vector.    Does adding an extra head shim (I have one original) help tame the FP 40's runaway characteristics?
I have another one and I try to use 11/3 props or something like that.  Using those props does help.
Re: FP 40, Does adding a head shim help tame the run away?
« Reply #1 on: January 01, 2014, 10:46:38 AM »
No not really, that is not the problem people had with them, problem one was the 20 size Needle vavle assem.  in them, it was near .30 thou smaller diameter than the old OS 40 bar, that made a .275 ventuurie closer to a 310 in area, big problem with trying to get used to calculating area, which most no one did, second problem was the tiny hole in the stock muffler, this caused heat and slow cycling...ie runaway.  adding a head shim just leans the motor out and causes more heat,most any time you decompress the engine it runs leaner ..hotter.
So use a 240 to 250 with the stock NVA or a 265 275 with a NVA that is .157 (PA  ST  Old OS  Enya), then use an open muffler, you can also run in a wet 2 if you have needle set problems
« Last Edit: January 15, 2014, 01:42:17 PM by RandySmith »
« Reply #2 on: January 01, 2014, 11:25:08 AM »
No not really, that is not the problem people had with them, problem one was the 20 size Needle vavle assem.  in them, it was near .30 thou smaller diameter than the old OS 40 bar, that made a .275 ventuurie closer to a 310 in area, big problem with trying to get used to calculating area, which most no one did, second problem was the ting hole in the stock muffler, this cause heat and slow cycling...ie runaway.  adding a head shim just leans the motor out and causes more heat,most any time you decompress the engine it runs leaner ..hotter.
  In fact, adding a gasket when not necessary might enhance the tendency to run away, since it has to run hotter.
     But, absolutely, to give yourself a chance you have to put a very small venturi on it, or an ST needle. I still think it's mostly a waste of time to run 40FPs when you can get a 46LA for $85, and that runs right with no fiddling.
Offline Paul Allen
« Reply #3 on: January 01, 2014, 02:08:48 PM »
Guy's
       Keen to learn, why adding a shim makes the engine run hotter?
In OZ
« Reply #4 on: January 01, 2014, 03:11:21 PM »
Guy's
In OZ
When you add a shim or decompress the head, you will have to turn the needle in...leaner... you will run leaner use less fuel and the engine will normally run hotter, adding nitro "can" cool an engine because you can then both run more fuel and oil for an exact given time, and you can turn the needle out and run the engine richer... richer is almost ALWAYs  cooler.
Offline Phil Bare
« Reply #5 on: January 02, 2014, 08:18:25 PM »
When you add a shim or decompress the head, you will have to turn the needle in...leaner... >
Randy, why would the fuel/air ratio change?
« Reply #6 on: January 02, 2014, 09:39:36 PM »
   I'm not Randy, but you lose power by reducing the compression, which will require you to run closer to the mixture closer to the ideal to compensate, hence, leaner.
    Most of what I hear people talking about with head shims is backwards, and this sort of stuff is becoming a lost art to some extent, since 4-2 break motors are rarely used for serious competition any more. You can still use the compression to adjust a piped engine, but you don't necessarily have to, so people have sort of lost the bubble.
   more compression: more overall power, bigger power difference between 4 and 2, faster transition from 4 to 2 and back, cooler (until you go over the top...)
   less compression: less overall power, reduced power difference between 4 and 2, and slower or delayed transition from 4 to 2 and back, hotter. In particular, it will tend to hang in a 2 longer due to thermal effects of running hotter in the first place. The ultimate expression of this is putting in so many head gaskets that it never transitions back to a 4, hence, runaway
I have found most of the piped engines I have used to lose power rapidly with compression changes (leaving everything else the same) but don't gain much in terms of 4-2 power difference, basically, you are only reducing the 2-stroke power only slightly faster than the 4-stroke power. That has made me try to control the 4-2 power break with the pipe and the prop, or, once we got 61s and up, run it in a 4-stroke all the time, pump it to the gills on compression, and not worry about the transition effects.
    That's not what generally happened with many 4-2 break motors. Reducing the compression tended to reduce the 2-stroke power and either do nothing, or increase the 4-stroke power, so slight compression changes would significantly effect the 4 to 2 difference but not hurt the overall power very much.
Offline Phil Bare
« Reply #7 on: January 03, 2014, 04:02:44 AM »
Lower compression, higher nitro, richer needle, cooler running?
Is this no so?
Regards, Phil
Offline Steve Fitton
« Reply #8 on: January 03, 2014, 07:04:17 AM »
I wish I had seen a description of shim effects this succinct about a dozen years ago.  When I get home I will print this out and tuck it into the pipe article in my Special Edition SN.
« Reply #9 on: January 03, 2014, 10:08:59 AM »
Hi Phil
You , have to change the ratio, when you jack up the head, the motor looses power, slows down, your lap speed goes down, line tension goes away, you have to turn the engine in leaner to gain RPMs so that you will get back to speed, Yes you can add nitro to**try** to make up the difference,  but that will change the air fuel ratio, and in many situations it makes no sense to decompress, then add nitro to get back where you were. Remember if you using say 6 oz fuel and you jack the head up, you then will run less fuel (and oil) thru the engine in the same amount of time. This normally adds to the heating increase of the engine.
 This thread was about engine heat and runaway. If you are facing that, decompressing is  not the way to go, You want to normally do something to make for a richer run, NOT a leaner one, Typically decompressing, then adding nitro only gets you back near where you were to start.
« Last Edit: January 03, 2014, 01:07:19 PM by RandySmith »
« Reply #10 on: January 03, 2014, 11:16:19 AM »
As a bit of a deviation from the original topic, something else that I have seen is that people want very small 4-2 power difference, and run the compression way down. That loses a bunch of power, so they open the venturi up to compensate - which works for some engines (Fox) and puts you in a death spiral on others (40FP).
   George Aldrich was one of the competent engine guys who took this approach to just about every engine. So he would greatly decompress, say, an ST60, then put on a massively large venturi to recover some of the power. In many cases I saw, this resulted in a pretty wimpy engine with a Fox-like 4-2 - lots of sound difference and negligible power difference. In thick air, and on light airplanes, it also sometimes resulted in the engine quitting during the takeoff roll because the fuel draw was so weak. It's a pretty sad state of affairs when an ST60 isn't enough power for a kit-sized Shark 45. Lew flew the +10% version with an ST46 with no real problems.
    It ran exactly like he wanted it to, like a big Fox - but just not much usable power. Maybe you didn't care in the 50s but you sure weren't going to be too competitive in the modern era if you were giving up power on your (already feeble) 4-2 break motor.
     A quickie field solution to this is to add copious amounts of nitro which helps get the power back and permits it to run richer on the ground, so it will get through the takeoff roll. I can recall have good results going from 5% to 17.5% nitro on a GMA ST60 at one of the NWR in Roseburg, but it would have been even better with 25% but I couldn't talk the pilot into it. The real solution is to put the compression back up, put on a smaller venturi, and regular nitro, then adjust the break with nitro, small compression changes, or prop fiddling like normal.
Offline Phil Bare
« Reply #11 on: January 03, 2014, 04:50:49 PM »
Most all European and Asian engines were designed to run on FAI fuel, no nitro, hence, higher compression. Engines designed here in the USA were designed to run with nitro, hence, lower compression.
An engine that 'runs away' can some times be corrected by using FAI fuel, or lowering the compression in order to use nitro. Some years ago, Duke Fox did some extensive work on developing engines for FAI fuel usage. Those engines wouldn't run worth two cents on any nitro fuel but ran fine on FAI fuel.
BTW, My .40 FP has one additional head shim, a very free flowing tounge muffler, and three layer of pantyhose material on the venturie.
11x3 props and ten percent nitro. 22 percent all castor.and no problems.
Regards, Phil
« Reply #12 on: January 04, 2014, 04:58:17 PM »
Regards, Phil
Hi Phil
Nothing wrong with doing it the way you have listed if, it works well and your happy, However I have setup hundreds of these, and the High comp with proper venturie size, good NVA, and open muffler just works better, more thrust, better power delivery etc...  That also goes the same for the FP clones such as the TT and Mag GP 40 and 44
Also  European ST 46, 35, 40, 51, 60 Super Tigers work best on NITRO fuel, So did Como engines, as well as HP engines, and the Asian Flash, OS engines, Thunder Tiger, Magnum , Royal, Blue Bird, and many others. So I don't think the majority were made to run on just FAI No nitro fuel.
Offline Phil Bare
« Reply #13 on: January 04, 2014, 07:49:28 PM »
Mine works well with good power for me the way that I have it set up. Any high compression glow engine will give better runs with low nitro/no nitro fuel. Reducing compression allows for the use of nitro.
Regards, Phil
« Reply #14 on: January 04, 2014, 09:22:09 PM »
Regards, Phil
   I know I am going to regret this, but none of the engines in this thread are "high compression" engines and almost all of them will run fine with any reasonable level of nitro stunt fliers put in them. A stock ST46, for example, loves 25% nitro, and certainly the FP isn't going to have any problem with it. You don't dare cut down on the head gasket or raise the compression ratio, but going from 5% to 25% is a non-problem with no changes required.
   I think the compression ratio of a 40VF is around 14:1, and have finished in the top 10 at the NATs in a 40VF running 17.5% nitro. I ran 15% in the RO-Jett at the 2003 TT, and I think I was down to about .005 head clearance to the point it was hard to choke - no issues.
     The general rule that you state is correct, but unless you are near the edge, you generally don't need to change the compression when you change nitro on stunt engines (the exception being the Discovery Retro). If you go over the top, it will be obvious as soon as you start flipping it.
Offline Phil Bare
« Reply #15 on: January 07, 2014, 04:07:59 PM »
Brett, the .40 FP has 7.4:1 compression in the CL version, the RC version has 10:1. Mine is an RC version that I converted to CL.
A Fox .35 has 7:1 compression, the VF has 10:1 effective.
If you can make them run with high nitro, more power to you.
Decompressing high compression engines has always worked fine for me, it tames them.
Offline Brian Hampton
« Reply #16 on: January 07, 2014, 08:48:43 PM »
Almost all stock engines have a compression somewhere between ~8-10:1 but I've found by experimenting that a compression of about 13.5:1 works best for zero nitro fuel so even with a 10:1 compression there's a fair bit of leeway for using nitro. I only have 2 engines that approach the best for zero nitro, the best being an Irvine 61RLS with 13.6 followed by a Bluebird 28 with 12.5:1. In roundish figures a Brodak 40 is 10:1, Enya SS45 S at 10:1, Enya 61 CXLRS Pro at 8.8:1, 46VF at 10.7:1 and ST G51 at 7.4:1.
While playing around with my G51 trying to tame a massive runaway (later found to be simply over heating) I tried reducing compression in stages down to around 5:1 and essentially all it did was reduce the power in both 2 and 4 stroke mode by roughly the same amount.
« Reply #17 on: January 12, 2014, 11:47:45 AM »
   It took me a bit to round up the comparisons, but the CL and RC version I was able to get my hands on were identical internally in all respects and roughly 11:1 based on port closing (rather than geometry)
Offline Phil Bare
« Reply #18 on: January 12, 2014, 02:46:28 PM »
Brett, I suggest that you may want to take a look at this page.
<http://sceptreflight.net/Model%20Engine%20Tests/OS%2040%20FP-S.html.
The .40 FP stunt engine is listed as having 7.4: 1 Compression and that that is the only difference from the higher compression RC version,
Regards, Phil
Offline Chris Wilson
« Reply #19 on: January 12, 2014, 04:35:36 PM »
Quoting geometric compression ratios in tests is the norm so the same engine that  has a tested 7.4:1 ratio could easily have a trapped ratio of 11:1.
Different methods to test the same result.
MAAA AUS 73427
« Reply #20 on: January 12, 2014, 05:20:09 PM »
Regards, Phil
I have had tons of the 40 FPs in my shop, both R/C and C/L  versions, all of the ones I have seen are  the same C/R , someone made a mistake in the measure or the article.
Matter of fact they are the same parts except for the carb  vs  venturie, and they did have 2 different mufflers,  and the Head  , which would be different for a higher C/R motor is the same on both and is the same as the FSR BB 40
Offline Phil Bare
« Reply #21 on: January 12, 2014, 08:17:28 PM »
Yeah, the article must be wrong................... LL~
« Reply #22 on: January 12, 2014, 10:03:56 PM »
Maybe I should clarify the compressions I mentioned in Reply #16 in that these are all geometric compressions, not trapped. However just for interest's sake I measured the exhaust port height on a typical engine and subtracted that figure from the stroke to get a trapped stroke which is what trapped compression is calculated from. Geometric compression on that engine is 10.75:1 and trapped compression worked out to be a tad under 8:1 giving almost an exact reduction for a trapped compression to 75% of geometric. On that basis a G51 with 7.4:1 would then have about 5.5 trapped.
Offline Geoff Goodworth
« Reply #23 on: January 12, 2014, 10:41:33 PM »
I will admit that I was not flying at the time the FP range was launched but the test that Phil linked to is the steel liner—early—version.
I've been told that when they were first released, the FP 35 and 40 were supplied with two venturis and several extra head gaskets. Given that, as Randy says,  the critical engine parts are all the same, I wonder whether the test engine was supplied with two head gaskets fitted.
While the discussion has focussed on combustion chamber volume, I can't help but wonder about ignition timing as well. For the stroke of an FP 40, 10° of crank rotation from TDC is about 0.010". The OS gaskets I've measured are approx 0.016" thick—possibly 0.4mm. What does an extra gasket—which moves the glow plug away from the piston crown—do to the ignition timing and the power produced?
« Reply #24 on: January 12, 2014, 10:53:59 PM »
The heads and liner timing is the same on both FP 40 RC and CL.....  would be extremely hard to change C/R  using the same parts, especially such a drastic change. The ones that were factory did NOT come with the extra head shims installed, they came just added to the engine box.
« Reply #25 on: January 13, 2014, 12:41:20 AM »
   I also dug out the parts list, and as expected, the piston/liner, crankshaft, connecting rod, head, and case have identical parts numbers. They also measure the same head volume, and the same piston depth at bdc, with identical port timing.
« Reply #26 on: January 13, 2014, 01:07:12 PM »
OK let me say this, The article is wrong if it says that..!! period.  However if you want to believe that, then I am OK with, I really don't care, I just put out the info, you can get out of it whatever you want. Matter or fact anyone that reads this can decide for themselves... I am OK with whatever  they want to believe.   You can lead a horse to water............  ;D ;D ;D
Offline Phil Bare
« Reply #27 on: January 13, 2014, 04:44:23 PM »
Randy, thank you so very much for giving me permission to believe what ever I wish to. I will stick with the article.
Maybe the horse is too smart to drink contaminated water.......... LL~ LL~ LL~
BTW, did you even bother to read the engine review
Regards, Phil
« Reply #28 on: January 13, 2014, 07:27:15 PM »
Regards, Phil
Phil  you wrote that the RC version has higher compression ratio, and you quoted an article that tells you that.... please see above...
I am telling you that it is a FACT, that is wrong, the RC version  does  * not * have a higher C/R..     that was my only point, matters not if you believe the facts, if the article says  what you said it does, then it is wrong.
Or the only other option is that someone stacked up the  3  head shims  to lower the C/R on one engine over the other, since all parts are the same, that would be one of the only ways to lower the C/R, but would be a bogus test since they did not ship that way, and the head shims would have to have been installed by someone before the test.
« Last Edit: January 13, 2014, 11:29:02 PM by RandySmith »
Offline Phil Bare
« Reply #29 on: January 14, 2014, 04:03:44 PM »
Randy, maybe you should go back and look at parts lists for the first .40 FPs with the iron and steel setup. That is what the test was done on.
The fact that the tester devoted so much time expounding on the difference in CR between the CL and RC versions makes no sense if they were the same.
Anyway, the setup that I have on the  iron and steel .40 FP of mine runs well and is dead reliable. It was converted from RC.
Regards, Phil.
« Reply #30 on: January 14, 2014, 04:29:10 PM »
Regards, Phil.
Phil
I did, I still have here both the FP iron motors and the parts sheet, Boxes, even the 3 pack of head shims included ( Separate ) in the motor box, as well as many new in pack parts for them.  ALL The parts are the same, The case is exact part number, piston sleeve..same part number, same with head, rod, wrist pin...  The C/R was identical, unless someone machined the head or stacked up gaskets, again  the article is wrong.
Or  maybe you can find a way both can have same identical head, P/S, Crank, Rod, pin.... and have a differant C/R ?????
« Reply #31 on: January 14, 2014, 04:42:15 PM »
I don't think you are getting anywhere with facts, Randy.  Maybe it would be more believable if magic was involved.   S?P
Offline Dennis Moritz
« Reply #32 on: January 14, 2014, 05:37:30 PM »
FP40S was shipped with extra head shims. If I am to believe my lying eyes. Saw what appeared to be more than one NIB FP40 with the extra shims put there by OS.
« Reply #33 on: January 14, 2014, 07:03:00 PM »
Maybe so Dennis but I did hundreds of FPs for people that came direct to me from the importer and none of mine had extra shims installed, they all had a sealed extra head shim pack in the box.   However that really does not matter because we are talking C/R , you can just as easy add shims to only the RC version and get backward results.....  OR maybe add 2 packs of shims to get a 4 to 1 C/R   ;D :o ::)
Maybe the OS engines in other countries were different than the   ones they sent us.
regards
« Last Edit: January 14, 2014, 11:42:19 PM by RandySmith »
« Reply #34 on: January 14, 2014, 07:13:28 PM »
maybe a magic ROD... that grows and shrinks as it goes up and down..???? Or maybe the CL motor had a magic flexible head that gave way under compression????
At any rate  not really worth the argument, if the test was with added head shims to one, but not the other, then it is a bogus test anyway. Then you get into how many shims? which engine? how thick are the shims? are the ALL the same size shims? did Some one  also put shims in an R/C engine that wasn't tested?
« Last Edit: January 14, 2014, 07:42:55 PM by RandySmith »
Offline Mike Keville
« Reply #35 on: January 14, 2014, 07:21:41 PM »
Questioning Randy Smith about model aircraft engines is like pi$$ing into the wind:  it's just gonna' come back and embarrass you.
« Reply #36 on: January 14, 2014, 11:07:31 PM »
Yes. I was referring to the extra head shims in the pack. Which I assumed were there to adjust the compression ratio and alter the performance of the engine. Why were they there? Why did OS think it desirable to adjust the compression ratio of this stunt engine by installing extra head shims and reducing the compression of the engine?
« Reply #37 on: January 14, 2014, 11:25:23 PM »
Right. This thread like many twists and turns. I have found that FP40S and the Tower40 (clone with a better P/L) are less problematic when running a smaller than stock .283 venturi with the stock needle valve. With the reduced venturi area, a free flowing exhaust, hot plug and the right prop, engines can be tuned to put out a lot of power and do a 2/2 break, useful in the pattern. Set up this way, adding a head gasket can soften the break. So it seems to me. I've had good luck with a .272 venturi when using the stock needle valve.
« Reply #38 on: January 14, 2014, 11:37:11 PM »
Hi Dennis
You maybe want to read the second post of this thread...  it is below
What I address with you is the C/R of the 2 engines , and the fact the shims were not installed, they were just giving you ones free, maybe because they screwed up the venturie size to Spray bar ratio and muffler outlet size so VERY badly
"Quote from: Allen Eshleman on January 01, 2014, 11:21:24 AM
I have another one and I try to use 11/3 props or something like that.  Using those props does help."
Randy Wrote:
No not really, that is not the problem people had with them, problem one was the 20 size Needle vavle assem.  in them, it was near .30 thou smaller diameter than the old OS 40 bar, that made a .275 ventuurie closer to a 310 in area, big problem with trying to get used to calculating area, which most no one did, second problem was the tiny hole in the stock muffler, this cause heat and slow cycling...ie runaway.  adding a head shim just leans the motor out and causes more heat,most any time you decompress the engine it runs leaner ..hotter.
« Last Edit: January 15, 2014, 07:05:21 AM by RandySmith »
« Reply #39 on: January 14, 2014, 11:40:19 PM »
 My post from a few days ago stating the extra shims were just put into the box as spares from OS, No One said they didn't exist  HB~> HB~>
« Reply #24 on: January 13, 2014, 12:53:59 AM »
   Reply with quoteQuote Modify messageModify Remove messageRemove Split TopicSplit Topic
« Reply #40 on: January 15, 2014, 12:06:23 AM »
      They didn't install them, they were in a bag. Compression is a useful adjustment, but not necessarily to solve runaway problems.
« Reply #41 on: January 15, 2014, 04:29:11 AM »
Right Randy. I thought we once talked about reducing the choke area of FP40s while using the free flow exhaust and so forth. Got it. Finally. Reducing compression will not solve runaway. But can soften break. And do other possibly useful stuff.
« Last Edit: January 15, 2014, 05:48:53 AM by Dennis Moritz »
Offline Luke Spreadborough
« Reply #42 on: January 15, 2014, 11:21:00 AM »
Excellent thread guys, extra thanks to Brett Buck for post #6 and #10. Very clearly explained.   H^^
« Reply #43 on: January 15, 2014, 12:24:00 PM »
Hi Dennis
Correct, it will soften the break, but it will reduce all power 4 cycle and 2 cycle, you will then run leaner because of turning in the needle to get power and airspeed back, what normally happens with the stock FP then is this, the motor is hotter because it is leaner, this pushes it more toward the "runaway" once it goes into a solid 2 stroke, it cannot cool down enough to get back to a 4/2 run. The answer for this problem on the FP is what i wrote at the top of this thread.
Offline Phil Bare
« Reply #44 on: January 15, 2014, 01:35:28 PM »
Randy, I will stick with the article.
As I said, mine runs very well set up with the added head shim, a drilled out tongue muffler, and three layers of panty hose  material over the venturi .
Regards, Phil
« Reply #45 on: January 15, 2014, 02:13:49 PM »
Regards, Phil
Hi Phil
I expected no less from you... when shown facts you believe what ya wanna....  The fact is the 2 engines are exactly the same parts, except for the mufflers and the carb vs venturie. Proven by both looking at the engines and the OS Parts sheet for the both.
« Reply #46 on: January 15, 2014, 02:28:08 PM »
Regards, Phil
Tell me Phil,
                   if you are going to stick with the article as being gospel then its logical to assume that, by way of proof, you have the stated compression ratio from that test.
Is this so?  Just curious to see if there is any hard evidence here.
Cheers.
MAAA AUS 73427
Offline Phil Bare
« Reply #47 on: January 16, 2014, 07:14:16 AM »
What ever you say, Randy.
Regards, Phil
Offline Phil Bare
« Reply #48 on: January 16, 2014, 07:20:22 AM »
Chris< here is the link to the engine test and review.
The information regarding the compression ratio is in the paragraph below the picture of the engine.
http://sceptreflight.net/Model%20Engine%20Tests/OS%2040%20FP-S.html  >
Regards, Phil
« Reply #49 on: January 16, 2014, 01:20:49 PM »
When I reduce choke area, I continue to run the engine in the sweet spot of the needle setting. The engine is throttled down. In my experience runaway is often confused with the engine running at near an optimum rpm for the venturi (fixed throttle position), prop, fuel, engine design. In other words the engine is running where adjustments are in balance. Before the reduction in venturi size, optimum (or near optimum) setting is putting out too much power for the stunt model, causing it to fly faster than we like. Reducing the venturi size throttles the engine back, matching performance to airframe. Setting the needle correctly, not over lean or over rich, will generally produce stable power delivery with a useful 2/2 break.
