The RSM 10X6 is outstanding on both Fox 35 and OS Max S 35 engines. It's pitch measures a little less than 6, so it is more like a 10X5.5. It is also light and pretty well balanced as it comes of of the package.Steve
I am building a "Ruffy" which will be powered by a Fox 35 w/hemi head and stuffer plate. Any suggestions for a prop choice would be appreciated. I will be using a uniflow tank and ST type needle valve assembly.
Brett, are we talking wood or nylon props?
If you can find them, I always found the Top Flite 10-6 (rounded blade, not the new PowerPoint type) to be the best overall. Brett
