  • July 18, 2025, 03:45:52 AM
Author Topic: fp-20  (Read 4211 times)
Offline Randy.Birt
fp-20
« on: October 29, 2019, 01:34:00 PM »
After some reading here on the site, i broke down and bought an FP 20 rc off EBAY.  Folks have really spoken well about this engine, so i figure i would try it. I have built and am finishing a Brodak Vampire. I have an OS Max 35-s Installed, but many folks have said that this it too much engine. Im not sure I totally agree, but I am ready to try good advice and switch to a smaller engine. As the 25 FP weighs similar to the 35s, I didnt want to switch to that engine (I have two of them) Also, the 25fp would seem to be the same power as the 35s, so no real help there.  If the 20 is slightly less power, and thereby appropriate for the vampire, I will think it is a good swap if it weighs less.
What say yall to that? Does the 20 fp weigh less than the 25 FP? Is this a better engine choice for the vampire than my 35s
Any information would be greatly appreciated.
V/R
Offline David Ebers
Re: fp-20
« Reply #1 on: October 30, 2019, 04:47:23 PM »
Looking at my FP manual, without muffler the 20 weighs 6.81 ounces and the 25 weighs 6.52 ounces. I have no experience with the 35-s. I have used the FP 25 with stock muffler, 9x4 or 10x4 APC prop on a Ringmaster and Barnstomer.  Neither seemed over powered.
Re: fp-20
« Reply #2 on: October 30, 2019, 05:40:22 PM »
... Also, the 25fp would seem to be the same power as the 35s, so no real help there. ...
Think of modern Schneurle-ported engines as "apples" and 1950's technology baffle-ported engines as "oranges".  Now, ask yourself how valid a comparison of the 35s to the 25FP (a Schneurle-ported engine) is.
The 25FP is way more powerful.
Actually, for sport flying, if you're willing to use all-castor fuel, the 35s may be a good choice, if possibly a tad big.  Based on my experience with Ringmasters, a 20FP is going to be a bit big (because - Schneurle).  If I had one, my next Ringmaster would get a 15LA or a 15FP.
Re: fp-20
« Reply #3 on: October 30, 2019, 08:31:31 PM »
David's specs make sense to me, tho I didn't confirm them. They're the same engine, except for a thicker cylinder sleeve in the .20FP. More brass or steel, so heavier. You can convert a .25FP to a .20FP if you can find the parts (piston, cylinder, wristpin and head).  y1  Steve
Re: fp-20
« Reply #4 on: October 30, 2019, 09:11:52 PM »
   25FP on a Ringmaster? If the engine is running right, I would expect about 3.5-3.8 secs/lap on 60ish foot lines. Do you have an aftermarket spraybar (ST, probably)?
Offline David Ebers
Re: fp-20
« Reply #5 on: October 31, 2019, 08:49:01 AM »
I am using stock OS venturi and needle valve with one layer of hose to keep crap out.
After rereading my reply,  I realize that I should have stopped after giving the different engine weights or should have expanded with my experience/results. So with apologies to Randy for halfa** info and to Brett for reading and agreeing with his advice how to run these engines then completely ignoring that advice (not out of "I know better than Brett", but out of willing ignorance and desperation), I'll relate my experience.
My first 2 flights (I was smart enough to short tank) with the 25 on the Ringmaster was the BBTU way. Using  9x4 APC prop at the recommended 11,000 or so rpm the engine ran great and consistent  thru my meager attempts at the beginner pattern. Brett is right, I was spinning around like a top at 3.5 second laps and couldn't keep up.
I then did what shouldn't be done with a stunt engine and backed the needle off to 9,600 rpm. What happened was that level flight laps where a comfortable 5 seconds. During maneuvers the engine would speed up to the point making it impossible for me to fly same size loops, squares and anything else. The end result of my trying run the 25 the wrong way was inconsistent runs, excessive speed up during maneuvers and a pile of parts and pieces of a Ringmaster and Barnstomer.
Re: fp-20
« Reply #6 on: October 31, 2019, 10:41:14 AM »
   You may well know better than me! I learn a lot from these threads, too.
   3.5 is right in the ballpark, when we tried the 20FP on Jim Aron's 20-point (at VSC) Ringmaster with a 20FP with the standard setup, it went 3.8 seconds a lap. Note that this was trying to solve a problem with the original Veco 19bb - which went too fast, too, 4.2 seconds a lap! Some solution that was. A 25FP is substantially more powerful than 20FP, so faster.
    In fact - 25/20 = factor of 1.25 (25% bigger). The power ratio between 3.8 second/lap and 3.5 second/lap is (3.8/3.5)^3 (cubed) - which is factor of 1.27!
     It's too bad about the crashed airplanes, but that was sort of the point - either it goes like a bat out of hell, or you needle it down, which works for a while until it takes off again - with whatever results. Point is, you are fighting the engine to try to reduce the power to something usable. In this case, 5.0 seconds VS 3.5 seconds is *a factor of 3* in the power - meaning, to first approximation, you are trying to needle it down to one-third of its capability.
  The original RC carburetor would do that OK, by restricting the venturi at the same time as reducing the fuel flow, more-or-less without changing the mixture. Our version of that is to reduce the fixed venturi size to something smaller.   An alternative is to use a similar much smaller engine - like a 15FP.
Re: fp-20
« Reply #7 on: October 31, 2019, 02:27:36 PM »
I'm curious -- what would you think of sticking with the 20FP but reducing the venturi by whatever means, or piling on nylon mesh?
Because the OP may have trouble finding a 15FP or 15LA -- there's only, like, a dozen on eBay right now.
Re: fp-20
« Reply #8 on: October 31, 2019, 07:12:33 PM »
" The 25FP is way more powerful. "
Think thisisa bitofa fallacy , ACTUALLY .
The FPs most renowned feature is its ' RUN ' being said to be the best of the FP's .
Incidently is a capital 'S' on the 35 .
A OS 30 ( same as the 35-S ) will haul a Demon combat wing around authoritively . On a 9x6 .
A Good Traditional 35 CAN work good on a 11 x 4 , maybe a 11 x 5 .A little Fp / FSR OS WONT .
Dunno if theyll swing a 9 x 6 as hard as the 35 - S .
Down on a 9 x 4 theyll pull away more revs tho .
My FSR 25 was blown around till 1/2 inch disapeared off the 10 x 6 prop . Maybe thats about the max .  :-X
Used a 9 x 4 black ridgid tornado prop on it , over 18 Kt. breeze . Tho takes a bit of footwork & co-ordination .
Found the 10 x 4 3 blade tornado ( the stiff silver ones )  good on long lines on the 35-S .
Putting a 5/32 ( 4 mm ) drill through the bearers carefully , as far as the nuts , can get both motors in the same plane ,
if angled bolts wont spoil your day .
Moral of the story being if you get the revs of the 35 S up where they are on the FP / FSR , youll find its got a few balls .
and the Std. intkes even o.k. then .
Re: fp-20
« Reply #9 on: October 31, 2019, 07:52:58 PM »
   That (as smaller or sleeved-down venturi) would certainly be a solution for a Ringmaster, an alternate would be to run less pitch. I don't want to discuss the other obvious alternative, enough people come up with that one on their own.
     I have no idea what a Brodak Vampire is, or how much power it will require, so it may be fine as-is.
Offline Randy.Birt
Re: fp-20
« Reply #10 on: November 01, 2019, 07:32:31 AM »
Thanks Brett for getting into the discussion here. After extensive reading, I realized that I bought the wrong FP 20. The one I have is the steel sleeve engine, not the ABN that you have written about extensively. I am hopeful it will still work well though.  Do you find the steel sleeve engine to produce a good run, or should I continue looking for the (now elusive) FP 20 ABN.
Thanks a bunch.
Re: fp-20
« Reply #11 on: November 01, 2019, 09:14:41 AM »
Brett:  I looked it up on the Brodak website.  The Vampire is about the same size as a Ringmaster, possibly a bit smaller.
Randy:  From what I've read here over the years, the steel sleeve FP should work fine, especially because you're not asking much power from it.  Just keep in mind that it'll be less forgiving of the fuel: you probably want to read this thread about choosing fuel -- I certainly hope it has info on steel/iron engines in there!
If I were in your shoes I'd proceed with the 20FP, because I'm chronically curious and because I'm a tightwad.  If you have money to fling around, there's those OS 15 engines I mentioned.
There's usually also a ton of Enya 19's and 15's, but those are baffle-ported engines and I have no experience with them (other than running an eBay impulse buy in my hand -- but I haven't flown it).
Re: fp-20
« Reply #12 on: November 01, 2019, 10:41:13 AM »
   I would just try it and see!  I haven't run the iron-liner version enough to really explore it. It will care more about the oil content, and you want more oil than the ABC version.  Based on testing a large number of these small engines, the important finding was that *they all work pretty good*, as long as you don't try to "improve" them too much, and run them like modern engines rather than trying to replicate 1955. That means running 4" of pitch and in a two-stroke.
Re: fp-20
« Reply #13 on: November 01, 2019, 07:34:25 PM »
If it's too fast with 4" pitch, try less pitch. APC does have some 3" pitch props, and MAS has some 4" or 5" pitch props that likely measure more like 3". Plus, you can re-pitch pretty much any of them, but you need some sort of a pitch gauge.  y1 Steve
Rick_Huff
Re: fp-20
« Reply #14 on: November 02, 2019, 05:51:53 AM »
I've been flying a Ringmaster for the last couple of months with an FP 25 and a Brodak wood 9x3 prop.  On 60' lines  I get 4.6 sec laps with the engine running in a solid 2-stroke.  While the engine seems to be screaming, the lap times are just right for a Ringmaster (in my opinion)
Rick
Re: fp-20
« Reply #15 on: November 02, 2019, 01:28:36 PM »
   That sounds about right - whether that is better than the other options is a matter for experiment.
