  • July 17, 2025, 01:30:44 PM
Author Topic: Fox35 needle valve  (Read 1799 times)
Offline Bob Disharoon
Fox35 needle valve
« on: February 18, 2007, 03:11:33 PM »
What is the best replacement for the stock fox needle valve assembly..something that will bolt right on with no modification?..also, is such a modification REALLY needed for easier starting performance, etc.? thnx in advance, BOB ??? ???
Offline Leester
Re: Fox35 needle valve
« Reply #1 on: February 18, 2007, 03:22:56 PM »
I'm sure the moderator Randy Smith can set you right up. No guarentee you won't have to drill for proper size though.
Leester
ama 830538
Online RandySmith
« Reply #2 on: February 18, 2007, 10:13:04 PM »
HI Bob
The brand of NVA  will have no differance in teh way the motor  cranks ,but can have a huge differance in the running and the setting of the motor
The Best one in my opinion is the  PA style  Stainless  NVA, it is a bolt in direct replacement but is much finer , this makes it needle  much better ,
Randy Smith
« Reply #3 on: February 18, 2007, 10:43:34 PM »
I have used about every variation there is for Fox 35 NVAs.  ST, OS, Fox, and PA.  I will never buy another of any kind other than the PA again!  It fits perfect, and the collett nut locks with out having to use a wrench like on an ST.
Bill <><
« Reply #4 on: February 19, 2007, 07:17:55 AM »
Thanks for the help..NOW then, how and where do I order one..BOB <= <=
Offline brucefinley
« Reply #5 on: February 19, 2007, 10:31:49 AM »
From Randy Smith's PA Aero Products!  These are truly fine pieces.
Bruce
« Reply #6 on: February 19, 2007, 04:06:19 PM »
I went to his site..nice stuff!..but could not find the pa nva after looking for 30 min...do you have the link handy?..thanx in advance..BOB H^^ H^^
Offline Leester
« Reply #7 on: February 19, 2007, 04:32:21 PM »
Just give him a call 678-407-9376 or email.
Leester
ama 830538
Offline Dick Fowler
« Reply #8 on: February 19, 2007, 05:53:24 PM »
I like the O.S.Max spraybar/needle valve assy. #22311000 . It is the same O.D. as the stock Fox spraybar ~ .134"  the ST spraybars are ~ .156" and choke down the cross sectional area.
Tower has them http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=000443397&I=LXCR49&P=K
Dick Fowler AMA 144077
Kent, OH
Online RandySmith
« Reply #9 on: February 19, 2007, 08:36:03 PM »
Which is the  main reason I had the Stainless  PA  NVAs  made to fit perfect in both diameter and width , unlike the OS NVA these don't float around the hole because they are 1 1\16 of an inch too small at the case opening, and many times they will  leak
Offline Phil Bare
« Reply #10 on: February 21, 2007, 05:48:46 PM »
Whats wrong with the Fox needle valve assembly?
