  • June 27, 2025, 03:21:37 AM
Author Topic: Tornado prop questions  (Read 1149 times)
Offline Ken Deboy
    • Silk and Dope
« on: February 16, 2007, 06:52:47 PM »
I have a Tornado 9x6 three blade prop that I have some questions about. It's made of a silver/grey plastic, blades are pretty flexible. The part number is either 963T or 6162 (it's marked with both). Do I need to do any prep work (boil it or whatever) before flying? How do you balance a 3 blade prop? How do you balance a plastic prop - I'm assuming you don't sand the heavy blade like on a wooden prop. Would this prop be a good match for an OS 35S on a Chizler?
There is a fine line between "hobby" and "mental illness"
Offline Tom Luciano
Re: Tornado prop questions
« Reply #1 on: February 16, 2007, 08:15:12 PM »
Ken,
 The way I balance all my props now is use thin CA on the light side. Put one drop on at a time , smooth it out,works perfect and doesn't weaken the prop.
  Tom
AMA 13001
« Reply #2 on: February 16, 2007, 08:42:23 PM »
HI Ken,
One of the pictures in the construction article on the Chizler shows exactly that prop. ;D
I have seen pictures of several planes of the '60s with the silver Tornado 3 blade on them.
Bill <><
