  • July 07, 2025, 11:15:22 PM
Author Topic: Which engine for a Score ARF ?  (Read 907 times)
Offline frank mccune
« on: May 27, 2019, 09:29:29 AM »
         Hi Folks:
         I must get my Score in the air this Summer and I would like to have some suggestions as to which engine that I own would be the best choice.  The list includes:
     HP .40
     Fox .40-.45? Banjo Back
     OS SF .46 Ringed
     OS SF .46 ABC
     ASP .61
     Which would be your choice? Will these provide enough power for Stunt flying?
        Tia,
        Frank McCune
Re: Which engine for a Score ARF ?
« Reply #1 on: May 27, 2019, 09:35:13 AM »
  Plenty of posts on this subject in the archives. These came out heavy. Mine weight 72 ounces with a Saito .56 in the nose and balanced right on the money. Of what you listed, the OS .46 SF ABC may have the ponies to sport fly it, if propped correctly. I don't know about the ASP.61 but definitely has the displacement but don't know how acceptable of a stunt run it will give you. I don't recall ever seeing one in any of the contest listings.
   Have a safe Memorial Day Holiday,
« Reply #2 on: May 27, 2019, 10:44:20 AM »
        Hi:
        I found a Super Tigre .49 SPORT which has been recommended as a good engine choice for the Score.  Thoughts re. the ST?
        Tia,
        Frank
« Reply #3 on: May 28, 2019, 02:23:18 PM »
The few well flying Scores I’ve seen all had ST 51’s or Enya 61’s in them.
« Reply #4 on: May 28, 2019, 03:45:13 PM »
I think the ASP would be too much.  I'd go with the OS SF, or maybe the Fox if it's in good shape and you need nose weight (I have a couple, and they way a ton, each).
