  • June 19, 2025, 04:02:11 PM
Author Topic: Fox needle question  (Read 963 times)
Offline Tim Chenevert
Fox needle question
« on: November 20, 2017, 03:22:31 AM »
I have a Fox needle valve part number 01341 and can not find any info on this needle to see what engine it fits. I called Fox but they had no clue on their part. Anyone have any ideas? Happy Landings, Tim
Baton Rouge Bi-Liners
AMA 179681
Re: Fox needle question
« Reply #1 on: November 20, 2017, 02:37:12 PM »
Tim,
I think you should post a photo of the NVA. Is it a straight through needle with spray bar or a remote needle assembly?
Best,   DennisT
« Reply #2 on: November 20, 2017, 03:30:41 PM »
It is a straight through spray bar. Trying to find out if the pointed needle will work good instead of the original flat needle that came with it. The spray bar is original too. Tim
AMA 179681
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #3 on: November 20, 2017, 04:06:44 PM »
Hello Tim Had a look at my Fox needles and part numbers 01314 and 13517 were both 35 Stunt tapered needles and 13510 was a whole 35 assembly. Fox did seem to change numbers for the same part but does sound like a 35 part. Regards Gerald
« Reply #4 on: November 20, 2017, 07:00:36 PM »
Thanks Gerald. Looks like I am heading in the right direction! Tim
AMA 179681
