  • July 10, 2025, 07:30:27 PM
Author Topic: ST G21 .35  (Read 1625 times)
Offline Leester
ST G21 .35
« on: May 31, 2006, 04:32:50 PM »
What kind of run can I expect from this engine? And is a 10-6 the prop to use? APC,MAS or wood? Was planning on 10-22 fuel 50/50   Thanks
Leester
ama 830538
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: ST G21 .35
« Reply #1 on: May 31, 2006, 06:58:45 PM »
You literaly have a tiger by the tail with that engine, it's a screemer but lots of fun on a Flight Streak. It's basically a combat engine designed to run flat out on 20% nitro. You will be fine with 10-22 but expect to be running 75 or 80 MPH.
Re: ST G21 .35
« Reply #2 on: May 31, 2006, 08:02:56 PM »
    Oh, maybe, depending on the particular model  - I have seen at least 4 different engines that were nominally G21-35s). But I flew mine with 5% nitro in a 4-2 break with more-or-less acceptable results for my skill level at the time. It's certainly not an ideal stunt motor, and it's trivially easy and cheap to get a better  motor, but if you have one it's not impossible.
       I recall that I ran an Rev-Up 11-5 with the stock venturi and *no muffler*, which ought to date it pretty well. Certainly has more ponies on tap than a Fox 35, which was my basis for comparison at the time.
     Alternately, you could sell it on eBay and then use the proceeds to buy 3 46LAs or Magnum 36's, but that's a different issue.
Offline Leester
Re: ST G21 .35
« Reply #3 on: June 01, 2006, 01:57:23 AM »
Thanks guys, I bought it a year ago and by accident I found it has the same bolt pattern as a K&B Stallion 35. I have a plane set up for the Stallion and was just wondering what the ST 35 would be like in the RSM P-40, it's also real close in weight to the K&B. I'll try the 11-5 and see what happens.
Leester
ama 830538
