  • June 19, 2025, 06:26:05 PM
Author Topic: fox 59  (Read 1137 times)
Offline John KruziK
fox 59
« on: January 18, 2011, 05:31:21 PM »
How much clearance should there be between crankpin and rod? This is a ringed engine. Thanks John
AMA 874027
Offline Chris Wilson
Re: fox 59
« Reply #1 on: January 18, 2011, 06:54:44 PM »
Between the crankpin and the rod? (As in the big end?)
Zero or a freely sliding fit that really can't be measured.
Being ringed or not should have no bearing (pun intended) on this one.
But perhaps you mean the crankshaft counter weight and the rod?
MAAA AUS 73427
Offline John KruziK
Re: fox 59
« Reply #2 on: January 18, 2011, 06:58:47 PM »
I do mean between crank pin and rod. It seems that there is a few thousandths, it has a little wiggle room.
AMA 874027
Re: fox 59
« Reply #3 on: January 18, 2011, 08:10:04 PM »
The clearance between the conrod and the crankpin should be so small as to be immeasurable but I have seen poor fits last along time due to the fact that rod only really acts in compression and needs little in the way of a tight fit.
MAAA AUS 73427
Offline Ward Van Duzer
Re: fox 59
« Reply #4 on: January 19, 2011, 08:37:46 AM »
Most folks taking apart engines don't realize that connecting rods are made to fit one way on the crank pin. Note that the pin has a rounded surface where it meets the crank shaft. Sort of like a small filet. The hole in the connecting rod is chamferred on one side, and drilled straight on the other. The chamferred end goes on the filet! Otherwise...MISFIT!
W.
Re: fox 59
« Reply #5 on: January 19, 2011, 08:13:18 PM »
Angular rock is normalish , maybe 4 degrees . any more is a bit much .
