  • July 17, 2025, 07:00:58 PM
Author Topic: Fox 40 Stunt, any good for stunt?  (Read 5047 times)
Offline Tom Weedon
« on: January 06, 2010, 08:29:53 AM »
I have a Fox 40 Stunt (model 14000) that I bought some years ago on Ebay. It seems to be in almost new condition since it has great compression, no scratches on the mounting lugs and a nice shinny, clean finish overall. My question is, "Is this a decent engine for stunt?"  I've heard conflicting reviews and it leaves me puzzled   n~.  What say ye experts?  ???
Tom Weedon, AMA 2537
Re: Fox 40 Stunt, any good for stunt?
« Reply #1 on: January 06, 2010, 09:33:52 AM »
Send it to the Silverfox Lew Woolard.  He does not participate on the forums anymore, but does advertise in "Stunt News".  He is located in Wichita Kansas if you want to google his phone number.
Offline Marvin Denny
« Reply #2 on: January 06, 2010, 01:57:26 PM »
  Tom, is that the one that has a bolt on venturi and the "wart" bypass boost port? It is sometimes called the "large case" engine.  If so, it makes a decent stunt engine out of the box except it is a little on the heavy side.  Lew Woolard does rework those some too though and when he gets through they are pretty darn good.
  Bigiron
marvin Denny  AMA  499
Offline Tom Weedon
« Reply #3 on: January 07, 2010, 04:44:02 AM »
Here are some photos of the Fox 40 that I have. There are several different Fox 40's
Online Robert Zambelli
« Reply #4 on: January 07, 2010, 06:16:01 AM »
Tom - I spoke to a Fox sales/marketing guy many years ago about that engine.
He told me that it was designed and/or developed by George Aldrich and intended specifically for stunt.
I would suggest NOT modifying it until you try it. You may find that it's fine as is.
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: January 07, 2010, 08:46:44 AM »
No mods necessary on that one. I think George and Fox designed it to be Fox's answer to the ST-46. The one I had had a lot of torque but didn't like high RPM and was only bench run. The main knock against this engine was its weight and size. Power will not be comparable to modern engines but at least it is heavy. I could see it used on one of the larger OTS designs or a sport model but would pass on putting it in a modern or classic stunter.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #6 on: January 07, 2010, 09:59:47 AM »
Think of it as a Fox 35 on steroids, I learned the stunt pattern with that engine on a really big profile back in the 70's. Still have the engine which is now powering a Dancing Girl bipe (same wings as the 38 Special). I wouldn't hesitate to use it on anything around 500-550 sq/in. Only real draw back is the large mounting foot print, you almost need to build an airplane specifically for it.
This is a photo of the profiles my buddy and I built to learn the pattern with, he had a Shark 45 kit. We used the 2nd or 3rd rib out from the root, built straight wings and used the Shark numbers for everything else. We both bought Fox 40's to power them with and I don't remember either one of wishing we had chosen a different engine. Thinking we were running 11-6's either Rev-Up or Top Flight on Super Fuel.
« Reply #7 on: January 07, 2010, 09:17:27 PM »
  I agree with Bob on that one.  It is a very good stunt engine right out of the box.  It is extreemly hard to get broken in as the sleeve is VERY hard.
  I have five of then and had one in a T-Bird once --the second version--  and it would do the pattern easily.
   Bigiron
Offline PatRobinson
« Reply #8 on: January 07, 2010, 10:27:58 PM »
Hi guys,
I had a Fox 40 like this years ago and the biggest problem with this engine I experienced was the very long bronze bushing for the crankshaft got so hot and tight the engine had less power than a Fox 35 or it would seize up. I gave it to someone and they gave it back to me.
Then, a combat guy who ran plain bearing Tigre 35 engines in his planes told me what to do.
First, disassemble and clean engine with alcohol or etc. Use a tiny stone to remove any burrs from any edges on the crank.  Then use progressively finer sandpaper to remove machine marks or rough areas, until the crank looks like it was polished chrome. Lightly polish the bronze bearing with 600-1000 sandpaper to lightly smooth it.
Second, He told me to spin the crank in the empty crankcase and listen. If it makes a zinging sound it is ready to use and if it doesn't then go to the next step. Next you lap the crank in the bushing with old fashion toothpaste. (He used lapping compound but he warned you could easily go too far without experience.) You chuck the crank in a drill and lap for awhile. Stop clean everything up, then spin the dry crank in the crankcase and listen for the zinging sound. If yes -you are done, if not - repeat the process. The goal is a sweet spot that is a low friction fit without any side wobble or excessive fuel blowing out the front. I had a whole new engine that I could finally keep running well enough to properly break-in the piston-sleeve. I changed the mounts to K&B 40 size. This 40 was equal to my Stan Powell K&B 40, using the same prop on the same airplane. I liked it.              Pat Robinson
Offline Tom Weedon
« Reply #9 on: January 08, 2010, 05:53:38 AM »
THANKS FOR THE HELP!!!!!   #^
This is what I love about Stunt Hanger. It is a BIG help to be able to tap into the vast wealth of knowledge out there in the C/L world. It sure beats the way it was in the old days when there was no one around to help answer questions about our favorate hobby. I have a Veco Thunderbird (original kit) that ended up at 46 oz. (ready to fly) and I have a new Fox 35 in it. I had a TBird back in the early 60's. I loved it but it seemed to be a little underpowered. Now I have this new one that I built last year with a new Fox engine and I'm afraid it may not be enough, so I'm looking at alternatives. To change engines will require modifications since the nose and upright cowl is tight.   ~^
Offline Bob Reeves
« Reply #10 on: January 08, 2010, 08:32:46 AM »
I wouldn't hesitate to dill another set of holes in the engine mounting lugs and/or even cut them down to help make it fit.  This will make some see red but that engines isn't particularly collectable and even if it were once our generation is gone none of this stuff is going to be worth anything. Might as well get as much use out of anything you can now before it's all over.
« Reply #11 on: January 08, 2010, 01:39:16 PM »
Hi Tom
You will find the motor a very good motor for stunt, when broken in properly, It will NOT however put out ST 46 power, It is an engine that likes props like 11 x 6 as it doesn't respond well to being run hard or high RPMs, use it in Nobler Chipmonk sized ships and use a 6 pitcch prop, it has a very mild break and will be a Great Motor for a long time to come for you, Keep in mind it does weight a lot more than a 35
Offline PatRobinson
« Reply #12 on: January 09, 2010, 10:01:09 AM »
Hi Ty,
Yep, the getting hot symptoms are what I experienced, except my symptoms were probably worse.
This Fox 40 has the longest plain bearing I have seen in any engine and it adds so much heat to the engine that it distorts the whole break-in process. After I solved the bottom end heat problem, breaking in the piston sleeve became a more normal process, but it does take some time.
Tom,this is a long stroke engine with good torque so I used 12x5 Rev-Up props or cut them down to 11 5/8" x 5 Rev-Up depending on the plane. I also use some 11.5"x 6 props some of the time, in some conditions.
        Pat Robinson
« Reply #13 on: January 15, 2010, 06:59:44 PM »
Like Randy, Marvin, and the others, said, it is a good stunt engine out of the box.
George told me one night (during a marathon phone call! LOL!!) that Duke oriinally was going to make an R/C Pylon 40.  Then he decided it wasn't goona work so he asked George to set it up for stunt.  The case has a molding that shows where a front ball bearing would have initially gone.
I used a couple of those 40s, one in a T-Bird II and it flew it quite nicely.  Not a ST 46, but more than a Fox 35.  I found it to have a very similar run to a good Fox 35, but it would swing an 11" prop easily. ;D
(NEVER had ANY luck side mounted on a profile!)
Mongo
Offline 50+AirYears
« Reply #14 on: January 19, 2010, 11:43:08 PM »
Glad I decided to look into this thread.  Somebody actually gave me one of these engines a few years ago, and I've been wondering how useful it was.  Really found the reference to one being used on a Shark 45, as I have one NIB, and have been contemplating using my ST-51.  The Fox would be more in keeping with the era.
Tony
« Reply #15 on: January 20, 2010, 12:23:21 AM »
   I don't think that's going to be a good combination unless you build it very very light. It's nowhere near as powerful as an ST51 (or a 46, for that matter) and that's about as small an engine as I would use.
Offline Bob Reeves
« Reply #16 on: January 20, 2010, 03:38:12 AM »
I agree with Brett, we used them on Shark sized profiles but times have changed and the profiles were much lighter than a Shark can be built.
Offline 50+AirYears
« Reply #17 on: January 20, 2010, 12:30:51 PM »
Suggestions noted!  Sounds good to me.  Maybe my Midwest (ex Kenhi) Panther then?  Of course, I also have a couple hundred plans either on paper or in my computer.  Should be able to come up with something for that.  And for my old Anderson .49.  Something Classic or OT.
Now, if only my wife gives up her plans for moving to South Carolina, and lets me get back to building and flying in peace!
Tony
« Reply #18 on: January 20, 2010, 01:59:57 PM »
Hi  Brett is 100% correct , and telling you like it is, that is NOT the motor to use for a plane as large as a Shark
It would be a good Chipmunk motor or a plane of that size, try to keep it in the 525 to 585 sq in range
The Shark need a motor that will deliver a lot of power.
Offline Douglas Ames
« Reply #19 on: January 20, 2010, 03:05:21 PM »
  Bigiron
Here's mine...A Fox Warthog .40 with the new Fox NVA (nice!) and a Mac's flow-thru. Plan to use it on something in the future.
AMA 656546
Offline 50+AirYears
« Reply #20 on: January 20, 2010, 07:36:41 PM »
While we're on the topic of Fox .40s for stunt, does anybody have an opinion about using the Fox .40 Schnuerle, both the older large case, and the current small case, and/or the Fox .45/.46 large case Schnuerle?  I have at least one of each, and a couple of the Fox CL venturi assemblies for the large case engines.
Reason I'm asking, is I once had an RC Bipe somebody gave me that was about a pound heavier than the suggested build weight, and the only engine I had that fit it was the small case .40.  Took forever to get off the ground with a 10-6, needed a short dive to build up speed for loops.  Then, I switched to a wood 11-5, and while the RPM dropped to just above 11,000, the takeoff run dropped to about 100', and the plane started flying like it should, inside and outside loops from level flight.  Just kind of suggested to me that the non-carb .40 version would be fairly decent with an 11-5 or 12-4.
Tony
