  • July 09, 2025, 11:44:38 PM
Author Topic: ST-.51 Question "Made in China" version.  (Read 2629 times)
Offline Andrew Borgogna
  • Andy
« on: March 22, 2010, 05:32:39 PM »
How do you remove the crankshaft from the crank case?  I tried the tapping the crank with a rubber mallet method and it didn't budge.  Any help would be greatly appreciated.  Right now it's in the crock pot getting cleaned.
Andy Borgogna
Andrew B. Borgogna
Re: ST-.51 Question "Made in China" version.
« Reply #1 on: March 22, 2010, 06:45:24 PM »
Just put a block of wood on the back, and another block on the front to protect the shaft, and put it in a vice. Once the tapered collet and drive spool come loose, it will come right out. Sometimes they are stuck so tight you have to heat it with a heat gun a little, to help it along. At least it works for me.
  • Andy
« Reply #2 on: March 22, 2010, 08:19:50 PM »
Thanks Jim, believe it or not that is exactly what I was planning to do.  I seemed to remember there is a tapered brass bushing behind the thrust washer, but I just wanted someone to confirm it.  Again thanks for the information.
Andy
Andrew B. Borgogna
« Reply #3 on: March 22, 2010, 10:23:56 PM »
If you can , pour boiling water , on the prop drive spool , or hit it with propane torch.
The expansion should see it remove itself . Save the big ammer  . BEARINGS side loading
isnt nesesarily conducive to there well being .
CLEAN the collet thourougly in thinners before refitting ,
Black grime in that area can allow the prop to rotate till the spool goes 'ping' on retightening with the 12 " shifter !
Offline fred krueger
« Reply #4 on: March 23, 2010, 10:36:18 AM »
You can use a small gear puller on the thrust washer (no impact to damage the bearing).  Then the crankshaft should come out with a slight tap on the end, unless it's full of dried oil.  In that case, heat it slightly with a torch and it should come out easily with a couple taps on the end with a plastic hammer.
Fred
« Reply #5 on: March 23, 2010, 10:34:19 PM »
Fred
Or set the engine on a flat pan in the oven once you have removed the drive washer (I got an OS drive washer puller from Tower).  Put the oven on about 400 degrees, and you will hear the crankshaft drop onto the pan.
Big Bear
« Reply #6 on: March 23, 2010, 10:54:47 PM »
Would you have a glare at the bearings , and tell us where there Mnfgd . Botswana etc ?
Might need an eye glass . Which are fairly usefull for looking highly technical !
« Reply #7 on: May 08, 2010, 05:20:24 PM »
Rubber mallets suck. They don't ever do much moving of the part, but you might just get it in the forehead on the rebound, or give yourself elbow problems. Get a good plastic mallet, or just use a block of wood and whack it with any suitable steel hammer you have handy. Just because the hammer is big doesn't mean you have to swing it like you're killing snakes.  %^ Steve
Offline Brian Hampton
« Reply #8 on: May 09, 2010, 12:50:22 AM »
You can't use a gear puller on the ST drive washer because there's nothing to grip. There's a very thin lip that goes over a machined portion of the crankcase and that's about it, the rest is flat. Heating the drive washer and pressing is about the only way to get it off. Other than my method which was to have a bad crash which loosened it :). The drive washer is actually a bit of a weak point for the hamfisted because it's a hollow casting which can split if too much pressure is put on when tightening a prop. It does help get it off though.....
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
« Reply #9 on: May 09, 2010, 07:06:50 AM »
If the bearing is removed, scan it at high resolution to read the numbers.
AMA 77370
« Reply #10 on: May 09, 2010, 11:22:31 AM »
Hi Brian
I have removed 100s and 100s of ST drive washers with my gear puller, Mine has a curve ground into the L arms and is ground sort of like a scissors blade, no problem using it to remove the drive washer.
Also if you are NOT going to reuse the bearings then driving them out with a vise , press, hammer or whatever is OK. I would NOT reuse them though.
« Reply #11 on: May 09, 2010, 12:04:12 PM »
   I use a battery terminal puller with no issues. I did grind it to have a curved end and a sharp edge, but there's enough to grip it with.
« Reply #12 on: May 09, 2010, 01:36:32 PM »
Me to; I have used the battery terminal puller on all of my engines that have a a groove in the drive spool. I also have a small gear puller that works pretty well also. The worst ones to get off for me have been the larger Saito 4 strokes. Sometimes I have to try all of my ways to get them to come off. On my Saito 90 twin, I had to resort to the gear puller.
  • Andy
« Reply #13 on: May 21, 2010, 03:36:21 PM »
You know I never responded to this thread, and I was the one who started it.  The mallet worked just fine, the crank came out after a few good hits.  Since then then the bearing were replaced and the ring was replaced and the engine runs better than ever.  A friend came up to me last Sunday and reminded me of this thread and asked me what I thought of the  ST .51.  Well out of the box I think the the control line version is a very good engine.  Since running the engine with the new ring I would say change the ring at the git go.  The new bearings are good, but there is no noticeable change in performance.  I really like the ST .51 and would recommend this engine for use where it's weight is not a problem.  I am running the Chinese version and cannot see any reason why this is not as good as the Italian version.  Maybe the ring on the Italian was better but I have no way to prove that.  Frank Bowman will size and install a new and better ring for a very reasonable cost.  Should I get another ST .51 I would have the ring changed out before using it.
Andy
Andrew B. Borgogna
