  • July 08, 2025, 07:53:40 AM
Author Topic: Fox 40 ABC Deluxe  (Read 1862 times)
Offline t michael jennings
  • AMA 83322
Fox 40 ABC Deluxe
« on: January 29, 2017, 06:42:32 PM »
Randy,
Have several Fox 40 ABC Deluxe engines.
Can these engines run on 23% castor/synthetic oil or do they require 28% castor/synthetic oil?
These engines have run on 28% oil content for several years.
Considering to use the 23% oil, if it will not harm the engines.
Thanks for the information.
T Michael Jennings       n~
Knoxville, TN.
Online Motorman
Re: Fox 40 ABC Deluxe
« Reply #1 on: January 29, 2017, 08:42:40 PM »
blank
« Last Edit: March 06, 2022, 09:35:34 AM by Motorman »
« Reply #2 on: January 30, 2017, 08:59:39 AM »
Hi   as  MM  said  , they should be just fine, so try it and  see, unless  they are really  varnished  heavily  i don't see  any problem
  • AMA 83322
« Reply #3 on: January 30, 2017, 02:59:48 PM »
Gentlemen,
Thanks for the info.
Michael Jennings
Offline Al Ferraro
« Reply #4 on: January 30, 2017, 11:19:52 PM »
   My Fox 40 Deluxe ABC would not run on Power Master GMA 10-23% oil fuel. Every time I did a loop or eight and pulled out level the engine would quit. I tried many different glow plugs and always had the same problem when I was running a fast 4 2 4 break. The cure was to run 10-20% oil, half caster/synthetic fuel. The engine really ran well with the 20% oil fuel and any good plug would work, some guys could not believe that it was a Fox40 after they heard the engine run. My engine is mounted on a profile, APC 11.5x4 prop, .285 Venturi, PA needle valve assembly, uniflow tank, and stock muffler.
Al
