  • June 23, 2025, 06:45:03 PM
Author Topic: Shaft extension for Fox Stunt 35 EJC49  (Read 1505 times)
« on: November 11, 2014, 11:57:15 PM »
I have a Fox Stunt 35, I believe it's a 1958 model EJC49.
I can't quite get enough threads on the shaft to install a Dubro spinner with a backplate when I use a 10x5 prop. Almost, but not enough for safety. Is there an extension I can use to adapt to this spinner? Searching turned up some confusing answers.
Rusty
Offline Bootlegger
Re: Shaft extension for Fox Stunt 35 EJC49
« Reply #1 on: November 12, 2014, 04:20:43 AM »
 Something else that you might try is a spinner with a thinner back plate.
 Check the Tower Hobbies web site as Great Planes makes one that I use a lot, and this is one of the reasons...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dick Pacini
« Reply #2 on: November 12, 2014, 09:31:59 AM »
Draw me a sketch and I will make one for you...no charge.
AMA 62221
« Reply #3 on: November 12, 2014, 09:42:49 AM »
Thanks guys. If Gil's suggestion doesn't work out for me, I'll get a sketch together for you, Dick. I appreciate your generous offer.
Rusty
« Reply #4 on: November 12, 2014, 02:03:15 PM »
I wonder if this is 2" spinner with the aluminum backplate is one of the thin ones.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMY1&P=ML
The specs say the backplate thickness is 1.8" but that makes no sense. That must be the diameter.
Rusty
« Reply #5 on: November 12, 2014, 06:12:47 PM »
That's a good spinner, Rusty. A bit of a hassle to get the prop aligned, but not too terrible. A lot of guys throw out the funny metric screws and tap the backplate to 4-40 and use socket head cap screws...a real good idea! To my way of thinking, any spinner with a plastic backplate sux...
I often use this (see link) prop nut/washer from Dave Brown products. The washer is hardened and the nut is stepped, so can screw onto more threads on the crank snout. When I use a Randy Aero spinner, I use a Gr.8 SAE flatwasher and a steel 1/4-28 coupler nut from the hardware store.   H^^ Steve
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXB952&P=7
« Reply #6 on: November 12, 2014, 10:20:27 PM »
...I often use this (see link) prop nut/washer from Dave Brown products. The washer is hardened and the nut is stepped, so can screw onto more threads on the crank snout. When I use a Randy Aero spinner, I use a Gr.8 SAE flatwasher and a steel 1/4-28 coupler nut from the hardware store.   H^^ Steve
That's the ticket!
Thanks a bunch, Steve. You've helped me out yet again.
Ordering one now.
Rusty
