  • July 08, 2025, 09:18:35 PM
Author Topic: Should I move the tank up or down?  (Read 1815 times)
Offline frank mccune
« on: June 08, 2014, 04:45:56 PM »
       Hello All:
       When I am attempting to fly my profile stunt/combat airplane, the engine cuts out when I try to do any form of an outside manuveur.
        The plane has a Fox .35 Stunt and a wedge shaped uniflow tank mounted with the wedge on the centre line of the engine. I replaced the previous tank for the same reason. it would cut out if any outside moves were attempted.  It too was a wedge shaped uniflow tank also located with the widest part of he wedge on the C/L of the engine.
       I seem to remember tht the Fox, as well of some other engines need to be mounted with the
 centre line of the tank located either above or below the C/L of the engine to get equal engines runs upright or inverted.
      I am guessing thet the Fox needs the tank to be mounted about 3/16" above the C/L when the plane is flying upright.  For some esoteric reason. the engine will now run well in both attitudes.  Am I correct about mounting the tank above the C/l or do I have this backwards?
      Which way shouuld I move the tank?
        Tia,
        Frank
     I was informed that the tank had not been made correctly and that I should tear it apart and check the plumbing. AAAAAAAAAAAAAAAAAAAAGGGGGGGGGGGGGGGGGGGGGGGG
Re: Should I move the tank up or down?
« Reply #1 on: June 08, 2014, 05:25:52 PM »
       Hello All:
   This is a well-known defect with the Fox. Don't do anything to the tank, please see this thread:
http://stunthanger.com/smf/index.php/topic,35138.0.html
« Reply #2 on: June 09, 2014, 09:34:09 AM »
      Hi Brett:
      Thanks for he tip!
      I spent hours researching the Fox .35 Stunt fuel feed problems and the concensus is that one must block off part of the intake bypass that is cast into he block.  This is the only Fox .35 Stunt that have flown that did act in this manner!  Perhaps it is time to try another Fox.  I have used a Fox .25 with the three bolt backplate on this plane with great success.  I was getting more "break in time on this Fox .35 Stunt as it is a dream to start! First flip starts almost everytime!
     Before I do anything drastic, I am going to change the plug and check the hole in the spray bar, Enya,. I do not think that is tank related as I did an A-B test with another tank and got the same results.
     Perhaps it is time to stop using old Fox engines and get with the more modern ones!!!  Lol
                                                       Stay well my friend.
                                                       Frank
« Reply #3 on: June 09, 2014, 01:12:32 PM »
If it burps and dies or misses a beat and keeps on running, stuff the bypass.  If it goes rich for about a 1/4 lap before dying inverted, raise the tank.  A uniflow tank on a profile mounted Fox 35 needs to be a bit above the centerline of the engine.  Somewhere between 1/8-1/4" is about right.
   You almost can't put it far enough off to quit, and still have the tank on the fuse, unless you did something strange. It will keep running with it WAY further off that you can likely get it.
   Once you get the bypass stuffed properly, it's very close to what you suggest. Most of the radical offsets are to try to fix the gas flow issue, which it doesn't.
« Reply #4 on: June 09, 2014, 02:32:45 PM »
Oh, well nevermind then.   :)
« Reply #5 on: June 09, 2014, 05:00:01 PM »
     Hello All:
     I gave up on the Fox .35 Stunt today!  I replaced it with an older Fox .25 with the 3 backplate screws.  This engine has always run very well for me.
     The retired Fox .35 Stunt would make a great Foxberg engine as it starts very easily hot or cold.
      I tried moving the tank, changing the plug, fuel, NVA, prop, etc.etc. but to no avail! I am not about to spend time working on a Fox .35 Stunt when there are many more modern engines for sale the work work great out of the box! Heck there are also some old engines that perform better than the Stunt .35!!!
     Thanks for all of the suggestions!
        Stay well my friends,
        Frank
Offline Steve Fitton
« Reply #6 on: June 09, 2014, 07:13:23 PM »
Hold onto that Fox 35.  When you put it in a built up fuselage model (like a Gieseke Nobler) instead of a profile, you will find it has no run hiccups and it will feel like it has 3 times the horsepower it had in the profile mounting.  Then you will see what a true 4-2-4 stunt run is really like!
