  • June 19, 2025, 11:18:51 PM
Author Topic: O.S. LA stock needle valves  (Read 2260 times)
Offline rich gorrill
« on: October 31, 2013, 05:58:44 AM »
Hello all, this may be a redundant question but why does everyone hate the stock needle valves that come on the LA 25 and 46 motors? I did some searches but all I could find is the backplate which is plastic are prone to leaks. I'm on a pretty tight budget so I hate to spend $90. bucks for an engine and then have to spend another $40 or so on replacement parts. If i'm just sport flying my Flite Streak or Magician do I still need to invest in the extras.
Thanks, Rich
Offline Russell Shaffer
Re: O.S. LA stock needle valves
« Reply #1 on: October 31, 2013, 08:50:51 AM »
The stock needles have a slight lag when adjusting.  Probably from the fuel in the line between the needle and venturi.  It is also a long ways from the needle to the prop, which is something I really appreciate.  I say fly with the stock one until you break something.  I put washers under the backplate screws and try not to over tighten and it will probably last a long time.
Russell Shaffer
Klamath Falls, Oregon
« Reply #2 on: October 31, 2013, 10:24:32 AM »
Thanks, Rich
    As far as I can tell, for the 30-40 flights I have flown so far, the stock arrangement on the 25LA is just fine. The one knock I have on it is that one click is a little too big. That's not too surprising since the taper on the needle is much steeper than the old front needle. I also question the durability of the backplate in inverted crashes, it seems like it will break the first time you pancake it inverted into the ground. People tell me they leak but mine doesn't, yet, and if it does, we still have the old reliable silicone bathtub caulk.
     I am running the current 25LA ABC RN *exactly* as it comes out of the box, with NO changes at all in any way. I even used the preset needle for break-in, and it fired on the first flip at a perfect break-in setting. It runs remarkably well, and I have seen no reason to change anything. I have a thread about it here, nothing much to say, take it out of the box, bolt it in, attach 9-4 APC, flip and fly.
« Reply #3 on: October 31, 2013, 10:43:13 AM »
"Flip and Fly".  That was also my experience with the 2 or 3 OS46LA engines, I have been using.  The first 2, I put on the test bench for break-in.  After a minute or so of running, it was apparent these engines require no break-in.  They held a steady 2-stroke with no sagging or heating.
It certainly saves the trouble and time of bench running before an engine is ready to use.
The remote N.V.A. takes a little getting used to, but I appreciate the safety factor.
« Reply #4 on: October 31, 2013, 10:54:30 AM »
<< snip >>
<< snip more >>
I would be awfully tempted to cut the needle valve assembly free of the backplate and make a bracket to mount it either to a couple of backplate lugs (like the FP 20 remote needle), to the engine mount lugs, or to the fuselage so that it is parallel to the cylinder and protected by it.  That's how my FP 20 needle is mounted.  It's basically in a position where it won't touch the ground in a crash, and it has survived innumerable inverted crashes.
Or if you fly in a way that you can have both hands free for adjusting the needle, leave it loose and hanging by the fuel tubing.
« Reply #5 on: October 31, 2013, 12:26:26 PM »
    The older arrangement with a separate bracket (that could be moved to various positions) was definitely better than the current version as far as this goes. It would be rather irritating to try to cowl the engine in on a full-fuse airplane, too. The cowl split line would be in the wrong spot or at a funny angle.
« Reply #6 on: October 31, 2013, 12:36:18 PM »
Tim is right about cutting the needle assembly off.  I broke one of mine (inverted landing) and was lucky enough that it didn't get into the backplate itself.  I made a bracket for the broken off assembly and am still flying it.
Russell Shaffer
« Reply #7 on: October 31, 2013, 01:07:43 PM »
Brett:
Heh.  I wasn't even thinking about a cowled engine.  Yes -- you are entirely right, and making a bracket may be even more of a help there.
Offline 55chevr
« Reply #8 on: October 31, 2013, 01:16:04 PM »
The remote needle valve set up worked extremely well on ducted fan models. But is was sensitive to small adjustments.  I don't see any reason it wouldn't work on a Stunt model.  This is one of the those deals where it isn't harder and it isn't easier, it is just different.
Joe
Joe Daly
« Reply #9 on: November 03, 2013, 06:48:00 PM »
I ran the .25LA awhile on a Skyray with the stock NV and backplate, and found it hard to start. I'd get fuel into the hose and venturi, and then it'd run back into the tank, and the prime would run out before it drew fuel up to the venturi again. It's not a problem if you use an electric finger, of course. I think the real cause of this is the loose fit of the NV threads into the spraybar...it wobbles like Elvis. I eventually drilled the venturi out to .272" and put in a .156" dia. spraybar...K&B in this case, but I prefer a ST Clone or Randy Aero NV Assy.
A club member had a twin with two .15LA's that apparently had one bad backplate. It'd go 3 laps and quit, every flight, same engine. Swapped engines L2R, and the same engine quit in 3 laps, but after replacing all the backplates with FP units, no more problems. Run the plastic stuff if you want, but know what to look for when the evil happens.  H^^ Steve
« Reply #10 on: November 03, 2013, 09:44:31 PM »
   I had the same sort of problem. What you need is the old 40VF hot-start "automatic choke" where you flip it and partially block the venturi at the same time, removing it once it goes.
    Is there any reason why large amounts of silicone bathub caulk wouldn't work? Its just a leak right?  Presumably after the plastic bulges out between the screws and the seal is lost. About 5 years ago I found an RC website that showed that as a cure.
