These swine are I think ' the Clone ' .
If I remember right , the timings 140 / 110 . Assume all the ' sticker I.D. ' on the bypass are the same , perhaps .
The ASP is said in there ads , to be Acceration Speed & Power . A.S.P. , not a Viper ! .
Their FSR 40 has 160 Ex Timing , way high for stunt & the higest of the FSR clones .
Dunno if the FS clone is the same trip , but would expect so . Incidently the ' Royal 46 ( or is it 45 )
Crank'd go in the FSRs & T.T. 46s , to stroke them . IF you ground down the O D of the crank web .
