  • June 20, 2025, 02:14:01 AM
Author Topic: aero tiger and thunder tiger 36 engines  (Read 2594 times)
Offline Bootlegger
« on: September 22, 2017, 12:55:28 PM »
  Fellows that are using these engines for stunt what N and oil mix are you using, I am thinking mostly syn, part castor (16% syn and 6% castor with 5% nitro), and long reach t/bolt plug, 10.5x4.5 A P C prop, wet two cycle at about 10,000 R P M..
  How does this compare to your set up?
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Target
  • C/L Addict
Re: aero tiger and thunder tiger 36 engines
« Reply #1 on: September 22, 2017, 07:37:48 PM »
I have a regular TT .36, so I'll be interested as well.
R,
Target
Chris
AMA 5956
Offline Gerald Schamp
« Reply #2 on: September 24, 2017, 01:21:54 AM »
Bootleggers set up works fine. Fuel can be SIG Champion 10/10/10, I pour out 4 oz of fuel and add 4 oz of SIG Castor oil. Engine runs fine, doesn't overheat and holds needle just fine. I don't tach it, just set it so its just breaking in and out before launch. Rocket launch, after about a lap or so it settles down and stays  that way through the flight. Little speed up burps at the end of tank, gives plenty of warning. I use a tongue muffler with 4 rows of 3/32" holes in it. Uniflow tank on suction only, no muffler pressure. Tried a commercial tube muffler and engine didn't want to settle down, my guess for what its worth is the motor likes a little back pressure, I think the extra Castor oil helps too.
Offline Target
  • C/L Addict
« Reply #3 on: September 24, 2017, 01:56:43 AM »
Hi Gerald-
So that's 4 rows of how many holes,  or how many total 3/32" holes exactly?
Thanks in advance.
R,
Target
Chris
AMA 5956
Offline big ron
« Reply #4 on: September 27, 2017, 01:17:16 PM »
If you want to know about the Aero Tiger there was one in a Vulcan in Oklahoma last week that was pretty dog gone good. I don't know if it could get any better than that one.
John Blanchard
Brusly, Louisiana
 AMA 1054488
