  • June 15, 2025, 12:42:55 AM
Author Topic: OS 46VF break in  (Read 2360 times)
Offline Peter Nevai
    • C3EL
OS 46VF break in
« on: March 01, 2021, 03:50:31 AM »
Hi Randy, I gather the 46 VF I sent you to have new bearings and the ABC piston and liner installed will need to be broken in again. What would the best way to do this? Thanks
Online RandySmith
Re: OS 46VF break in
« Reply #1 on: March 01, 2021, 11:28:42 AM »
Use fuel with 20% oil, mostly synthetic, 75-25  or so, Run it with a 11 x 4 prop, run the fastest 4 cycle it will run in, then turn the needle just into a 2 cycle for 10 seconds at a time. rotate back and forth between the 2 setting, I would run 4 ounces at a time, and try to use 1/2 gallon of fuel. When you decide  to run it in a plane, use a 12 to 12 1/4 x 4 to 4.25  prop 2  blade  or  11.5 to 12 inch  3 blade  with about  4.5 pitch.  We burned  about 5.5   to 6 ounces of fuel  piped, and a little  less  run on a muffler, Use a  hot  glow plug, like a  Glow Devil 300, big bore hot, etc
Offline Peter Nevai
    • C3EL
« Reply #2 on: March 10, 2021, 06:32:34 PM »
Thanks Randy. I have 11/ 4 two blade wood and 12 4.25 three blade carbon props.  I have a 6oz uniflow tank and Merlin Glo plugs. Is the merlin plug good? It wil be on a pipe.
Online RandySmith
« Reply #3 on: March 11, 2021, 08:50:52 PM »
The Merlin  2004  and  2005  are  good  for this engine,  i would  break in with the  11 x 4  2  blade
Offline Leonard Bourel
« Reply #4 on: December 17, 2022, 03:22:15 PM »
Thanks I got the answers i needed Len
« Last Edit: December 18, 2022, 12:29:40 PM by Leonard Bourel »
