  • June 15, 2025, 10:23:12 AM
Author Topic: Inside profile tank installation  (Read 1538 times)
Offline Harry Rountree
  • HARRY ROUNREE
« on: December 14, 2022, 08:53:24 PM »
Can you put a tank on the inside of a profile plane? how to make it work?
Re: Inside profile tank installation
« Reply #1 on: December 14, 2022, 09:05:12 PM »
  Yes, that works OK. The engine might have to be set pretty fast on the ground, to accomodate the fuel pressure going up as you take off and start flying.
  • HARRY ROUNREE
« Reply #2 on: December 14, 2022, 10:27:07 PM »
Oh Thats the difference OK
« Reply #3 on: December 14, 2022, 10:40:01 PM »
   That's probably better than the opposite. In this case, it's not very far inboard, so I think this will be fine.
« Reply #4 on: December 15, 2022, 06:02:10 PM »
If you like being awkward , putting a ' chicken hopper ' thing thru the fuse , uniflow . Would mean a small hiole in the fuselage .
Just use a say 3/4 x 3/4 x 1/2 deep square feed job tacked on , if its too much or a birch like it is .
Though tanks inboard of the spray bar usually work pretty good , for stunt .
  • HARRY ROUNREE
« Reply #5 on: December 15, 2022, 08:55:15 PM »
ahh now I see it "feeding the spray bar" as opposed to the "spray bar sucking fuel"     cool next plane gets that
