  • June 23, 2025, 06:01:26 PM
Author Topic: Fox .35 rebuild ?  (Read 1117 times)
Offline Rob Killick
Fox .35 rebuild ?
« on: January 03, 2010, 02:26:00 PM »
Hi ,
I just rebuilt a Fox .35 Stunt (50th anniversary) .
I used Fox' Ceramic P&L , Smith hemi head , Smith NVA , Smith Hi Zoot crank and a Fox stuffer back plate ...
No head shims and everything , except the back plate is metal to metal fit.
Is there anything else I can do (port blocking, maybe) to finish it off ?
Thanks ,
Rob K.
Rob Killick , MAAC 33300
Offline Leester
Re: Fox .35 rebuild ?
« Reply #1 on: January 03, 2010, 02:34:36 PM »
Rob: Just send it to me   y1 y1  It's to cold up there   VD~ VD~   It's a balmmy 11 above here.  LL~ LL~
Leester
ama 830538
Offline Rob Killick
« Reply #2 on: January 03, 2010, 02:46:11 PM »
Hi Lee ,
A "balmy 11" !
Damn heat wave :)
It's a shame my "better half" wouldn't appreciate a test run , in the basement LoL !
Happy New Year !
Rob
Online RandySmith
« Reply #3 on: January 03, 2010, 03:18:30 PM »
Hi ,
Thanks ,
Rob K.
Hi Rob
Yes the backplate should not be a metel to metal fit, I would use the gasket that was made to use on the backplate
I would also use  1  standard head gasket, try it this way before trying to not use any gaskets
Offline Rob Killick
« Reply #4 on: January 03, 2010, 04:48:18 PM »
Will do (head shim) ,
Thanks Randy ,
Rob K.
Online Geoff Goodworth
« Reply #5 on: January 04, 2010, 12:44:10 AM »
Rob, I would insert the transfer port filler.
I was given one NIB by one of our friends who thought I had a deprived childhood since I had never owned one. I consulted with Brian Gardner (Bristunt) who definitely recommended the port filler. I also used the stuffer backplate with Randy's crank and NVA. The engine has been bench run and I'm about to fly it.
Cheers, Geoff
