  • July 15, 2025, 07:35:48 AM
Author Topic: Trimming props - best methods  (Read 3275 times)
Online Dennis Toth
« on: July 06, 2014, 06:42:29 PM »
Guys,
Wondering what methods you have used to trim APC props to smaller diameters? I have used a stick gauge that Windy came up with (a piece of motor mount with the 1/4" bolt in one end with different lengths marked down it). This is a simple way to get both blades the same length.
Now this gets the correct diameter. What I have seen is the tip shapes and airfoil shape at the cut end can cause loss of performance vs. the original molded tip. Anyone find a method to keep the APC prop performance when cutting them down?
Bests,     DennisT
Re: Trimming props - best methods
« Reply #1 on: July 17, 2014, 10:34:59 PM »
Well, I needed an 11.5" diameter prop, starting from a 12.25 x 3.75 APC (see picture) for my piped .46VF. I first had to drill out the center hole to fit a .250" dowel pin, and then made a template out of poster board. Scribed around the periphery (bottom surface) with a #11 (indexing off the hole and TE). Belt sander took the outline to the scribe lines, and I started scraping the top of the prop with a fairly sharp knife blade. I found out the APC material will actually file quite decently, but scraping works great, followed by a little sanding, balancing, and polishing. Works fine!
But yes, the next step is some 3 blade Brian Ether flat backs or maybe an UC. We'll see on that. But for now, I've got a pretty useful baseline prop.  H^^ Steve
« Last Edit: July 17, 2014, 11:52:51 PM by Steve Helmick »
« Reply #2 on: July 20, 2014, 01:02:27 PM »
Get a prop scribe, and use a fine tooth metal hacksaw blade  in one of the small blade handles, Stanley and other make them and you can get them from Walmart  of most hardware stores
Tags: props
