CLICK HERE--><--CLICK HERE
Fox .35 Muffler Ear Improvements
Started by Dan McEntee, June 20, 2026, 05:37:32 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
   If you have been doing this event for any length of time, you know that there are several different vintages of Fox.35 Stunt engines that have appeared from the first ones in the late 40's to the last ones in 2014. The first ones had no mufflers or way to mount them. Then came the late 60s to early 7's when the tiny muffler ear appeared. It was barely there, and pretty fragile, so you have to use it carefully. Many just didn't use them. They finally got a full length muffler mount in the last versions that could survive a ham handed modeler or a crash and not break  off. I always figured there had to be a way to make the middle ones with the tiny ears more user friendly.
 I'm a welder by trade, and have always had access to a TIG machine, so I would weld on some metal to the exhaust stack to shape and drill for a more robust muffler mount. This is doable but not easy because the crank case soaks up oil like a sponge and can take forever to cook it out before you can add more metal to it. It took me a long time to figure out how to do it and it takes a long time to do. I did full length mounts like the last factory versions on occasion, but then decided that going half way was plenty strong, and that saved time. The problem with this is, not every one can do this, and not every welder knows how to do this!! I kept thinking of a way to beef up the stock tiny muffler ears and not need any special equipment, and then it hit me.
  If I put a length of aluminum tube along side the exhaust stack, exactly the same length as the distance from the ear to the edge of the stack, when you tighten the screw down, all the stress is transmitted to the muffler itself, which is stout enough to take it. If you clean and scratch up the case metal, you can glue the tube on and fair it in with JB-Weld and strengthen the whole joint. I have made up a few test engines over the years and tried them out and they hold a muffler fine. I have not crashed a model with one on it to see how it would survive a crash, but I don't think they would, depending on the crash. But if you are past the phase of crashing every time you go out, then that's not an issue. If the tubing tears out but doesn't break the ear off, you can just replace the tubing and the JB-Weld. This method should work with any muffler that attaches like the stock or almost every after market muffler I have seen. The tubing is standard K&S aluminum tubing from the hobby shop or hardware store, and I think the size is 17/32" which is the size that telescopes into 3/16" tubing. This all barely adds on a few grams of weight also. This might work with the order engines also if you can come up with a bracket or strap that lays against the back of the engine, and the tubing is sized just right so the muffler is clamped to the engine, and care can be taken not to clamp too hard and distort the case, which is very easy to do a a Fox .35 of any vintage. Check out the photos I'll leave here and see what you think, try it on an engine, and see how it holds up for you. The JB-Weld should take the heat well on the outside like that, and the rest will depend on how much you ruin the engine, how much oil it gets on it, and how much "stress" it gets in use!!
Like Like x 1 View List
  Here is what it looks like with a typical tongue muffler mounted/
Like Like x 2 View List
GERALD WIMMER
Hi Looks nice and should work fine but I think the JB Weld will go soft after a while from the heat. I have used JB weld a lot on model engines, car engines and tractor engines but it has its limitations , even glued a cracked V twin crankcase which lasted a little while. Mixed results with alloy welding on model engines too.
regards Gerald
Michael LeGate
There's several variations of JB on the market. 1, The original, take forever to set, hard as rock. 2, A fast set with a touch of flexibility. 3, a marine grade (?) that I have not tried. Just did a Fox 36 with busted horizontal ears. Scuffed up the 2 flat sides, drilled 2 1/16" holes in the exhaust stack for anchoring and blobbed original JB on. Shouldn't have any problems unless it gets stuffed.
Quote from: GERALD WIMMER on July 02, 2026, 04:54:15 AMHi Looks nice and should work fine but I think the JB Weld will go soft after a while from the heat. I have used JB weld a lot on model engines, car engines and tractor engines but it has its limitations , even glued a cracked V twin crankcase which lasted a little while. Mixed results with alloy welding on model engines too.
regards Gerald
    yeah, I have experienced it's short coming also. It won't last on a radiator repair as the glycol gets to it, and it's strength in certain types of joints is questionable. In this application, it just has to hold the tubes in place. It is bridging the gap between the muffler ear and the muffler itself, so that when the screw  is tightened, the ear can't get stressed and flex, and the tube is trapped by that same pressure. The exhaust stack will get hot, but when running and out in the air flow, it should stay fairly cool. The real heat will come from any soaking action after the engine shuts down. On a profile, I think it will cool off pretty quickly, and a cowled engine cool more slowly. Exposure to exhaust discharge should be minimal. In a crash, I have no expectations of what will happen!! But it just may limit any damage to the original muffler ears. Time will tell as to how long it may last, but if it lasts a few flying season, and comes loose, it can easily be replaced and renewed, or any other product that may work better can be tried. I think this method just gives the average guy a chance to make things a bit better at low cost and low work involved.
  Welding the sides of the exhaust stack just takes patience. The problem is that the casting soaks up oil like a sponge. I've found that no amount of heating with a torch will cook it all out. Using a TIG welder, I just start in one spot, and bring up the heat until oil cooks out, then stop and wire brush, and then repeat as needed. Soon, you'll seea little spot get shiny where it's clean and just getting to melting and puddling point. I make a dab with the rod to get it started, and then work slowly. Stopping from time to time to clean with a wire brush is common. I don't go all the way to the end of the exhaust stack any more. It gets too thin, and you need a steel back up bar in the stack to keep it from collapsing. Just going about half way is pretty stout, way better than the flimsy ear like we are used to seeing snap off so easy. Then drill the hole is easier when it's shorter also. I just do it because I can!! I have the machine and at least some deteriorating skills left!! I'm hoping to hear back from some others that have tried this tube method and see what results they get. It's better than nothing!!
Dave Hull
I saw a package of JB Weld "High Heat" epoxy putty at the store today. So I looked up the data sheet--and now I'm more confused.
Regular JB Weld claims it is intermittently capable of 550F temps. Of course, the strength drops with increasing temperature.
High Heat JB Weld (tubes or syringes) claims to be good to 550F.
High Heat JB Weld Putty claims to be good to 450F continuous, and 500F intermittent.
The question remains whether it is all substantially the same and just marketed differently, or....
Quote from: Dave Hull on July 03, 2026, 01:00:25 AMI saw a package of JB Weld "High Heat" epoxy putty at the store today. So I looked up the data sheet--and now I'm more confused.
   Yep, the real proof will be in trying it out and see what happens in the real world. But, like I said, in this application the JB Weld is just holding the tubing in place without a lot of actual stress except from vibration and some exhaust heat and oil. Time will tell. In the mean time I'll keep my eyes open for anything better.   If a guy only flies a model with an Fox .35 set up like this 6 or 8 times a year, it could last a long time, maybe indefinitely?
Dave Hull
Dan,
One thing I have noticed about JB Weld around the engine is that you do not want to cut into it or file it if you can avoid that. It seems that the "skin" of the curing epoxy is more fuel-proof than a cut or filed edge. I suspect this is because it is a filled epoxy (powdered metal filler) and once you cut thru the continuous epoxy skin you are now exposing a matrix with metal particles distributed throughout. Just a theory. But I stopped reaming out venturis that I "made smaller" with JB Weld. Instead, I wax up a drill bit and use it as a center mold piece when I can.
Quote from: Dave Hull on July 03, 2026, 03:53:57 PMDan,
   I kind of had that suspicion myself after some of my experiences. The surfaces always does look slick, and on the engine in the photos, I spent some time wetting my finger and smoothing it out as much as possible. The only thing I couldn't do anything about is when i filed it to make everything flat with the exhaust stack end so the muffler seals well. Before I run this engine, I might make a gasket from some of that green Perfect gasket material to put between the stack and the muffler. That may help seal anything that got filed off from getting too oil soaked too fast. Maybe even some of that aluminum duct tape might work well enough also.
