  • June 22, 2025, 12:43:47 AM
Author Topic: Fox 35 : Launch RPM ?  (Read 1585 times)
Offline Robin_Holden
« on: February 06, 2009, 09:38:10 AM »
Now .... Please don't laugh at this question !
What should be the launch RPM for a 'stock' Fox 35?
I've got a couple of these engines but I'm only now getting around to flying with them. I only came back to Stunt C/L a few years back and I've been concentrating on using my Enya and Tigre engines .
My Fox 35's are carefully run-in [ all castor based fuel ] and will use a [ recommended on this forum ]  25%/26% lube content made up half and half castor/synthetic. I'll be using Master 10x6 or Zinger wood 10x6 props.
Much obliged for any contributions ,
Robin [ ex-pat Brit in the Charente full of ex-pat Brits ]
Offline Jim Thomerson
Re: Fox 35 : Launch RPM ?
« Reply #1 on: February 06, 2009, 12:19:04 PM »
I am flying a Fox 35 on a Taipan 11 x 5 prop, releasing at 7,800. Peter Chinn (Aeromodeller 12/1967) says Foxes vibrate in the 7,000-9,000 range of RPM, but mine doesn't.  Peak HP is 0.45 at 11,500-12,000 RPM. He gives 9,700 to 10,300 on various 10 x 6 props. I'd suggest running your Fox nd let it warm up for a few seconds then tach it.  Set the needle where it is just breaking in and out of four cycle.  That should give you in the mid to high 9,000's.
Offline BillP
« Reply #2 on: February 08, 2009, 09:18:38 AM »
I don't set by tach but don't fly competition either. Instead, I needle to a full 4 stroke with an occasional 2 stroke break...and that depends on the tank setup, muff pressure, etc and how they perform in flight. But I use 25% all castor with 5 & 10% nitro and fly at sea level. My Fox 35s needle (stock flat or tapered) and actually fly best with 9.5x6 MAS nylon props and less so with MAS 10x5 or 10x6 woods. It might be different with your fuel and elevation but once the needle is set it generally stays that way from yr to yr and my tach use is mostly for testing props on the bench.
bp
Bill P.
« Reply #3 on: February 08, 2009, 11:17:56 AM »
     I can only guess (since a very strong engine needs more ground RPM and a weak engine needs less, and they vary A LOT, as do the propellors), but on 5% nitro, I would guess somewhere around 8100-8200 rpm. Note that unless you are using a TNC Tach, it probably doesn't matter because the readings are so random on the others that you can't compare from unit to unit.
     Most people set them by ear, anyway - with a 10-6 on a typical model I set it for 90% 2-stroke, 10% 4-stroke (just occasionally missing a stroke here and there), and then count on the unload to get it into a "just barely still 4-stroking" setting in level flight. From there, it's either too fast or too slow for the airplane, and adjust accordingly. We used to do "needle flights" every morning just to get it close, and that's probably still what I would do.
