  • June 20, 2025, 11:10:30 PM
Author Topic: Placing cylynder into crankcase? How  (Read 1622 times)
Offline frank mccune
« on: July 31, 2015, 03:40:39 PM »
    Hello All:
    Today, I had a deuce of a time getting the cylinder back into my OS .30 Stunt. Please tell me an easy way to do this.
        Tia,
        Frank
Re: Placing cylynder into crankcase? How
« Reply #1 on: August 01, 2015, 11:21:48 AM »
    Hello All:
        Tia,
        Frank
Frank it should just drop in.  Did you drop the sleeve?, is it gunked up?
need more info
« Reply #2 on: August 01, 2015, 12:30:42 PM »
      Hi Randy:
      Thanks for the reply.
      I have had this problem with other engines in the past and the problem seems to be that the piston catches on the inside of the cylinder preventing the cylinder from entering the case. I do not think that the cylinder is eccentric as there seems to be not tight spot.  Sometimes, I can get the cylinder to easily slide into the case but today it was a nightmare! I have seemed to have the best luck with the piston turned to TDC.  Perhaps this is incorrect.  I finally gave up and increased the chamfer on the i.d. of the cylinder with my trust Dremel tool.  I have done this in the past with success but it seems a bit crude.  Sometimes a man must do what a man must do! Lol
    Oh yes, I used a copious  amount of oil on all of the parts!
    Suggestions?
        TIA,
        Frank
« Reply #3 on: August 05, 2015, 08:57:21 PM »
It can be a pain sometimes as the piston will move from one side of the case to the other and catch on the sleeve. Sometimes it helps to hold the crank case upside down and the piston will then center better. The ones with the chamfered sleeves go pretty easy.
« Reply #4 on: August 06, 2015, 04:55:08 AM »
      Hello:
      Thanks for all of the tips! I am sure that this advice will make the task a bit easier.
        Be well my friends,
        Frank McCune
