  • July 31, 2025, 12:46:15 PM
Author Topic: Fox .35 fuel  (Read 1972 times)
Offline Kirk_Binns
Fox .35 fuel
« on: July 15, 2008, 05:35:14 PM »
Okay, I know that this has been beaten to death, but.....
There you are, in a town with a nice little LHS that only sells Omega Cool Power 5-25%.  They have to cater to the R/C folk.  But you, having flown R/C and beginning to learn how to fly control line, want to return to the Fox .35s that powered your uncle's Nobler and P-39 in the 60s.  Can the Omega fuels, with castor additive (I've got a source), be used in a Fox  .35 Stunt?  I know that the Fox is a lapped, bushed engine, but what I've read on this forum leads me to doubt that Cool Power is a safe adventure.
Offline Ralph Wenzel (d)
Re: Fox .35 fuel
« Reply #1 on: July 15, 2008, 05:51:45 PM »
The best answer I can give is . . . . Maybe.
If you're starting out with a new Fox .35, you can just bring up the total oil to 29%, starting with Cool Power 10% or 15% Nitro. If you're gonna use the Cool Power (base) with an older, well-worn Fox, you're very likely to end up with a dead engine, as the synthetic oil in Cool Power will scrub away the Castor "seal" that the Fox has built up.
Of course, you could order a Ceramic or ABC Piston/Liner set and avoid that particular problem, too. And especially with the Ceramic set, you'll get a smoother-running engine, too.
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Alan Hahn
Re: Fox .35 fuel
« Reply #2 on: July 15, 2008, 06:01:08 PM »
Well it is always worth a try. One thing to remember is that the oil in Morgan's Cool Power or Omega is actually less than 20%.
There is a fuel calculator somewhere around here (I saw it recently), so it will tell you how much castor to add to bring the oil to 29% (which I think I would recommend if you start with a Morgan fuel). I would say assume 17% oil to start in a typical gallon, and go from there.
Offline Jim Thomerson
Re: Fox .35 fuel
« Reply #3 on: July 15, 2008, 08:16:31 PM »
I think you will be fine kicking the oil % up to 29% with added castor.  I'm presently running a Fox I bought in 1977 and put a couple thousand flights on before putting it into its present airplane.  It has @ 150 flights on it with Sig Champion 10% nitro, 20% oil 50/50 synthetic/castor.  It has fine compression, gives first flip starts and reliable runs.  I probably flew it on all castor fuel in the good old days, as the head is baked on black.
Offline Marvin Denny
Re: Fox .35 fuel
« Reply #4 on: July 15, 2008, 08:26:00 PM »
  Kirk,  If you start off with 18 % oil, and pour off 16 oz of mix from a gallon, then add back to that gallon 16 oz of castor oil, you will end up with 28.25 % total oil.  Save the 16 oz you poured off and when you have used up  enough from the gallon of mix, pour the original 16 oz back into the gallon and add 3 oz of castor and you will still be in the ballpark as far as oil is concerned.  I would not try more than 10 % nitro (although many do go to 15 %  N.
  What part of the country are you in??  Perhaps someone is near enough to assist you some.
  Bigiron   in Wichita KS
marvin Denny  AMA  499
Offline Kirk_Binns
Re: Fox .35 fuel
« Reply #5 on: July 16, 2008, 07:09:27 AM »
Thanks all....only one known control liner in my area (there apparently was a huge club here in the 70s), and he owns the hobbyshop!  I'll ask him this week if he could get some Sig castor into the shop and follow you folks' advice.  No lack of R/C out here in Nova Scotia as there are four clubs all within a 60 nautical mile range, but control line just doesn't seem to have a following.  Given the declining number of R/C fields, I think the time is ripe for getting grass roots c/l model flying off the ground again.
Re: Fox .35 fuel
« Reply #6 on: July 20, 2008, 01:26:02 AM »
Hi Kirk,
Welcome to the forum, and back to C/L!
Follow Marvin Denny's (Bigiron) advice on the Fox .35.  He knows more about running a Fox than anyone else I have ever known!
Mongo
Re: Fox .35 fuel
« Reply #7 on: July 20, 2008, 09:44:21 AM »
Hello Kirk and welcome
you may want to read the fuel and engine article at the first of this forum, this is a small excerpt from it.
"So what percentage do you try? For motors like Fox .35s, OS Max 35s or the old McCoy’s and K&B’s, use a fuel with 26 to 28% oil content; preferably half castor and half synthetic, up to 75% castor  is OK. These  motors have very small bearing surfaces, and are subject to much wear and heat, most are all plain bushing motors and most have unbushed rods. They need a lot of  oil  to help cool the engines. Since these motors run hot, they need  extra oil to keep them lubed,clean, and to carry out heat . If you have one of these that is  in very good  shape but, is  just starting to get some brown or black varnish plating on it, the synthetic mix will clean it  up for you, resulting in increased life.  Do not use the synthetic  blend in an old motor that has a lot of time on it with all castor fuels; the synthetic will remove the castor varnish off the piston and sleeve and will in some cases, leave you with the worn-out motor that had to start with.  Also always try to NOT use  prop shaft extensions with these engine, as it adds a  lot of  wear on the crankshaft bearing.
So what percentage do you try? For motors like Fox .35s, OS Max 35s or the old McCoy’s and K&B’s, use a fuel with 26 to 28% oil content; preferably half castor and half synthetic, up to 75% castor  is OK. These  motors have very small bearing surfaces, and are subject to much wear and heat, most are all plain bushing motors and most have unbushed rods. They need a lot of  oil  to help cool the engines. Since these motors run hot, they need  extra oil to keep them lubed,clean, and to carry out heat . If you have one of these that is  in very good  shape but, is  just starting to get some brown or black varnish plating on it, the synthetic mix will clean it  up for you, resulting in increased life.  Do not use the synthetic  blend in an old motor that has a lot of time on it with all castor fuels; the synthetic will remove the castor varnish off the piston and sleeve and will in some cases, leave you with the worn-out motor that had to start with.  Also always try to NOT use  prop shaft extensions with these engine, as it adds a  lot of  wear on the crankshaft bearing."
You can with success, as Marvin stated add 15 to 16 ounces of castor to either Cool Power or Omega, But never run them as is in a Fox 35, many people have wiped out the rod on 1 flight doing this, by the way Morgan fuels are measured by weight, not volume so the 8% oil figure is really just a tad under 15% by volume, The last time I did a boil down test on their fuels I got 14.8 % oil.
This is the link http://stunthanger.com/smf/index.php?topic=4037.0
REgards
