  • July 16, 2025, 12:58:29 AM
Author Topic: Fox 35 fuel  (Read 1286 times)
Offline Dave Nyce
  • Flying
    • Revolution Sensor Company
Fox 35 fuel
« on: July 31, 2018, 12:22:29 PM »
Is the best fuel mix for a Fox .35 in a Nobler  5% nitromethane, 29% castor oil, balance methanol?  If so, is that same mix also good for other old engines, such as the McCoy .19 and McCoy .35?
Dave Nyce   New Bern, NC
AMA: L356
Offline peabody
Re: Fox 35 fuel
« Reply #1 on: July 31, 2018, 12:45:34 PM »
Should work fine.
They would be easier to needle at 10% nitro
Commercial fuels have other stuff in them
Re: Fox 35 fuel
« Reply #2 on: July 31, 2018, 01:35:06 PM »
NO it is  not the  "best" mix  a  far better  mix  would be 28% oil with at least 1/4 synthetic, I use 1.2 synth. and  use  whatever nitro percent you need, 5 or  10, caution on using 15% in the 35  as it  can  make the crankshaft depart  forward
see my fuel article on  the engine setup  forum
Offline Gary Dowler
Re: Fox 35 fuel
« Reply #3 on: July 31, 2018, 08:32:46 PM »
Notice the uniform assertion that the Fox engine needs a high oil content.  My 35 stunt simply would not run out a tank on 20% (50/50) oil, it overheats and quits. I upped to 30% by adding 10% pure castor and it behaved just fine after that. Its messier, but it works.
Gary
