I have a ST 60 RC version that I will get a NVA and Venturi for from Randy Smith. My question is this: Will it run well without any rework or does it need to be worked by someone to get a good 2-4 run from it? Does anyone have the same engine and can answer?
This is the engine I am talking about, It is an old ST V60
Randy, what diference beteen a twin ring and a single ring ST I realise the twin ring is older but wonder if one is better that the other
Randy,Do you sell mufflers for these older Supertiger engines? I need one for the older .40 that requires muffler straps, a couple of .46's and a .51 that has the taped hole in a web in the exhaust.Thanks, Artie
