Tim,
A last resort type of solvent to soften the gummed castor on the wristpin/conrod fit may be naphtha (lighter fluid). IF, that is, the problem is at that point. ...Probably is...
Oil it as soon after as possible, too.
Luck!
Also, curious what "degunking" you have in mind. If it is external, yeah, sure looks better without the scorched, darkened castor. Internally, though, some apparent gunk can be healthy. Hot castor, so the story goes, is driven into the somewhat porous cast iron piston material, and helps maintain seal with the sleeve clearance... Looks dark, but how many people are going to examine the piston skirt through the exhaust port?
