  • June 18, 2025, 03:52:24 PM
Author Topic: Tower 40 engine set ups  (Read 1511 times)
Offline Bootlegger
« on: July 26, 2017, 09:58:48 AM »
  Fellow's that are running the Tower 40's I am courious about your set up, prop fuel plug mods, if any, and any other info that you can share..
  Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Tower 40 engine set ups
« Reply #1 on: July 26, 2017, 02:46:06 PM »
  Thanks a lot...
you will  need to give your setup for answers, venturi  size   needle type, head motor stock modified butchered ???   etc
Offline Bootlegger
« Reply #2 on: July 26, 2017, 03:09:26 PM »
Randy, that sure would help, sorry that I forgot, the engine is stock, nothing done any where, using a .290 venture, your needle assy, and the rest is stock...
Gil Causey
AMA# 6964
« Reply #3 on: July 26, 2017, 03:54:05 PM »
My setup for the Tower 40 is to B&B the motor. ( balance crank make sure all fits are in specs) Cut heat dam on head, fins, and install  either  a  .255  venturi with OS NVA, or  better, a  PA NVA with  .281 venturi,  1 or 2 head shims, NO change to the Excellent head plug in, fuel with 22 to 24% oil mostly ( 3/4) synthetic  oil.  Bolly  12 x 4 is best I have ever seen on this, or  use a  Power Point  11 x 4, Z  pro 11 x 4,  Cyclone  11 x 4.5  2 blade props, launch in mixture cackling 4-2 or just barley into a 2 stroke, engine will unload within 1 lap  and get a little  richer,  open free flowing  tube, or  tongue muffler .
some get  a 11 x 5  and run a 4/2,  DO NOT  use as 6 pitch prop with this setup, it will  run away , DO NOt use a very restrictive muffler, use whatever nitro you need for the  Weather/altitude/humidity
Offline Bootlegger
« Reply #4 on: July 27, 2017, 08:14:26 AM »
  Put a .281 venture in today, this s to say thanks to every one for the help/advice... y1
Gil Causey
AMA# 6964
