  • June 17, 2025, 10:02:10 PM
Author Topic: fox 35 boom  (Read 894 times)
david smith
fox 35 boom
« on: May 24, 2009, 02:58:36 PM »
What would cause a fox 35 to break a con rod just below the wrist pin? I was using a 9-6 MA and sig 10/20 fuel.  It was running great and just started to lean out because the tank was low.  The needle was still where it was set at the beginning of the flight.  I would like to find out if it was something I did so I dont do it again. Thanks.
David
Re: fox 35 boom
« Reply #1 on: May 24, 2009, 03:55:56 PM »
I once had a Fox 35 which broke a rod because the bottom rod bearing got real sloppy and was clanking around.  I don't remember just where it broke.  I would recommend sending it back to Fox.  Their repair service is great, and maybe they will determine it is a manufacturing defect, and repair it for little or no cost.
Online Bill Barber
Re: fox 35 boom
« Reply #2 on: May 24, 2009, 06:07:25 PM »
                   David , the recommended fuel for Foxes was at least 25% oil , maybe that
      was your problem .
AMA 325076
