  • July 05, 2025, 03:38:53 PM
Author Topic: Silver Fox 40 Set-up  (Read 942 times)
Offline Mike McHenry
« on: June 04, 2009, 11:15:51 AM »
Would anyone one know what would be a baseline set-up for a Woolard Fox 40? i.e. Fuel (all castor or 1/2 and 1/2) and prop.  It will flown on a modified Twister.  Any help would be appreciated.
Thanks, Mike
Offline Balsa Butcher
  • High Desert Flier
Re: Silver Fox 40 Set-up
« Reply #1 on: June 04, 2009, 08:30:03 PM »
I've been running Lew's Silver Fox 40's off and on for many years.  I use powermaster GMA 10/22 w/ one ounce or Randy Smith's Aero Oil added.  Current prop I like is the RSM 11 x 6.  You could use that as a starting point.  RPM will probably be in the high 8000s, they will run a 4-2-4 break. Don't be afraid to experiment but they run more like a ST-46 than a stock Fox 40...that's a good thing.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: June 05, 2009, 04:48:48 AM »
Thanks Pete!
In the fuel all castor or mixed with some synthetic.  I have some of Randy's Aero Oil to add.  Glad to hear they run real strong!
  • High Desert Flier
« Reply #3 on: June 05, 2009, 07:55:08 AM »
I have always used the standard GMA 1/2 castor, 1/2 synthetic in my Silver Foxes.  I have never found that they require an all castor diet. Other's experiences may differ.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #4 on: June 05, 2009, 08:14:27 AM »
Thanks Pete!
