  • July 13, 2025, 07:20:37 PM
Author Topic: Fox 35  (Read 1797 times)
Offline John Watson
Fox 35
« on: September 03, 2019, 01:13:46 PM »
Trying to get a Fox 35 to run for my Ringmaster. The one I'm trying right now runs but I can't get a needle setting. It blubbers and runs rich but when I try to turn the needle in to try and smooth it out it quits. I have Brodak 5% nitro and 28% castor. It will run blubbering but won't smooth out...………
Re: Fox 35
« Reply #1 on: September 03, 2019, 02:12:58 PM »
John,
From your description it sounds a little like you have a plug problem. I have had good runs with a hot Enya#3 plug (I have also used the Fox plug work but not always, sometimes they get taters on them and don't hold the setting).
The Fox is a special engine and once you get the hang of running them they are a very good stunt motor for the right size ship, which the Ringmaster is just fine. Not knowing how much you have run stunt engines I will give a few basics (if you know this stuff please forgive me). Break the engine in slow on the Brodak 5%, 28% oil fuel, 9x6 prop, Enya# 3 plug (this is a good starting place, a Fox plug can work but may not). This takes about 10, 5 minute runs. On the last three runs do some lean-out bursts where you either lean the needle a bit at a time or pinch the fuel line to cause the engine to lean, holding this a little longer (20 sec) several times during the tank run. Once it will hold a lean run its ready.
OK, mount the engine on maple mounts, don't use hard Aluminum pads or if you do add 1/32" plywood pads under the mount lugs (to allow some crushing under to account for the mold draft angle of the mount lugs). Mount the tank so that the back end is kicked out about 1/8" and the centerline lined up with the upper head fin (the Fox likes the tank a little high and the first fin on the head is a good start point). Last, assuming you are using a uniflow tank set the vent up in the free air stream (see the attached photo).
For the first flight set the engine on the rich side so that if you pick the nose up to the 11 o'clock position it just breaks into a 2 cycle.  Once you get a feel for how it runs you can bring up the rpm a few clicks at a time to get the lap time in the 4.9 sec (assuming 60' lines).
If you start doing maneuvers you will likely develop the Fox "Burp" on outsides. This is what they do and it can be eliminated by running more of the 2+-2_2+ setting or do the stick in the bypass (see attached).
Good luck,    DennisT
« Last Edit: September 03, 2019, 02:45:15 PM by Dennis Toth »
Offline Robert Zambelli
Re: Fox 35
« Reply #2 on: September 03, 2019, 02:36:43 PM »
Good advice, Dennis.
Following your suggestions should produce a fine running Fox.
Allow me to add: Ditch the Fox needle valve, call Randy Smith and order one of his. They really work well.
Set the spray bar hole at either the 4 or 8 o'clock position relative to the venturi centerline.
For what it's worth, I prefer a different fuel. I use Brodak 10% nitro, 23% oil, 50/50 castor/synthetic.
I've also had very good results with the Merlin plugs the Brodak sells.
I've heard lots of good about the Enya plugs but I have no experience with them.
Offline John Watson
Re: Fox 35
« Reply #3 on: September 03, 2019, 02:49:58 PM »
Brodak was out of 10% nitro. I haven't had a Fox in 50 years . I appreciate all the input. Trying to maiden my first Ringmaster in 50 years. I need the needle you referred too. I have accumulated 6 Foxes and finally got one to run a full tank but the needle is all the way out. I am anxious to get my Ringmaster in the air.
Re: Fox 35
« Reply #4 on: September 03, 2019, 04:38:19 PM »
   If it's been sitting around for a long time, I would strongly suggest cleaning out the spraybar and needle assembly with various solvents (like lacquer thinner) and running a teeny bottle brush through there. They sell them at drug stores for going between your teeth, so they will fit in the spraybar OK as well.  The stock Fox needle is a variable quantity, but usually they will be able to get an acceptable ground setting. What happens in the air, that could be another story.
    Also, check that the two holes in the spraybar are aligned across the bore of the venturi, instead of one on top and one on the bottom. If they aren't quite centered, make it so the side they are offset to is on the downstream side of the venturi. Most of them are off-center a little. Some people think it is intentional, but it's more likely just a tolerance issue.
Re: Fox 35
« Reply #5 on: September 03, 2019, 09:02:01 PM »
   The components of s standard, stock Fox .35 can be anything but consistent, but if you have good fuel, good battery and a good plug, they will run. I have had Fox .35's that had to have the needle backed way out, which is where I tell people to start with the setting anyway. Back it all the way out, slide a length of fuel line over the threads the length of the threads, then put it back in about 2 turns. The threads leak air something fierce sometimes. Not to start it. If it still runs too fast, take the needle back out, file the flat taper on the end of the needle a little bit, then try again. You will eventually get a decent ratio and be able to get settings. If the engine has compression but is well used, it may be varnished up and will need to be cleaned up. That can drag a Fox down and run like it's blubbering. Check the piston to see if the baffle is at the back of the cylinder bore, and has not been assembled backwards. All the other modifications that are mentioned work and work well, and I have used them, but it is still possible and very satisfying to get a good run out of a box stock Fox .35 every now and then. It helps to give you an understanding of what all the other modifications are doing and why. You don't know what you can get out of an engine until you learn to get what you can out of it in it's original designed state.
Offline Al Ferraro
