Engine basics => Engine set up tips => Topic started by: Dan McEntee on January 17, 2022, 10:51:36 AM
I have an ad over in the classifieds, looking for a Fox .29 Stunt wrist pin. This is the .29 that looks like a .35 Stunt with the triangular back plate. I know there was a later version of the .29 that was a whole different engine, but the wrist pin may be the same. If anyone knows this for sire and can supply correct part numbers for them that would be a great help on finding what I need. The wrist pin for the .29 Stunt is hollow and has brass eyelets in the ends because the .29 did not use retainer circlips for the wrist pin.
Thanks a lot in advance!!
Did you check with MECOA?
Best, DennisT
Best, DennisT
I can't find a listing for it on the website. Back when they made this engine, they did part numbers way different. I may have to call them if I can't figure it out. I'm not sure when the stopped making the .29 Stunt. and I don't know if the later , bigger case .29 shared the same pin or not. I haven\t called primarily because i doubt anyone there would know!!
