Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 15, 2025, 07:58:27 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
FOX 29
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: FOX 29 (Read 821 times)
John Craig
2017
Trade Count:
0
Commander
FOX 29
on:
August 19, 2013, 06:13:47 AM »
The only parts unique to the Fox 29 are the piston, cylinder, & head? Wristpin? Everything else is interchangeable with the Fox 35? A bent crank in a 29 can be replaced by a 35 crank? If the 29 case is deformed a 35 case will work?
Logged
Phil Bare
Trade Count:
0
Captain
Re: FOX 29
Reply #1 on:
August 20, 2013, 02:21:22 PM »
You got it right, John, the Fox
.29 AND .35 are the same except for bore and the sleeves are interchangeable, the .29 has greater wall thickness.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
FOX 29
