  • July 12, 2025, 11:03:11 PM
Author Topic: FOX 29  (Read 819 times)
Offline John Craig
FOX 29
« on: August 19, 2013, 06:13:47 AM »
The only parts unique to the Fox 29 are the piston, cylinder, & head?  Wristpin? Everything else is interchangeable with the Fox 35?  A bent crank in a 29 can be replaced by a 35 crank? If the 29 case is deformed a 35 case will work?
Offline Phil Bare
Re: FOX 29
« Reply #1 on: August 20, 2013, 02:21:22 PM »
You got it right, John, the Fox R%%%% R%%%% R%%%% R%%%% .29 AND .35 are the same except for bore and the sleeves are interchangeable, the .29 has greater wall thickness.
